| Sponsors
| | | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | Ok, had dremel and we'll see how much damage I did. Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. Originally Posted by Motoschwinn
Ok, the plug is brown to dark brown. Only runs right with the choke is just ...  | |
08-18-2008, 11:57 AM
|  | Master Motorized Bicycle Builder | | Join Date: Dec 2007 Location: Essex, UK
| | Re: Ok, had dremel and we'll see how much damage I did. Quote:
Originally Posted by Motoschwinn Ok, the plug is brown to dark brown. Only runs right with the choke is just slighty on. I pulled the aircleaner off, and visually I would say the choke is about 15% on. | It looks like you need to richen the mixture - because that is what the choke is doing.
It used to be that alot of the old racers used to feather the choke control to gain just a little more power from their motorcycles.
Try raising the clip on the carb a notch if you can and see what it does then..
Cleaning off the plug with a wire brush will give you a better clue of what its doing per run..
Jemma xx
__________________ "....Look, no pedals... *thud*..." The mating call of the motorized-biker. "RetroEagle" - 32cc Two-Stroke, Piped. 35mph on #13 gear. Reversed stem with springer fork. |
08-18-2008, 12:20 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: Ok, had dremel and we'll see how much damage I did. You actually need to lower the clip a notch to richen it up. Lowering the clip raises the needle, which allows more fuel. |
08-18-2008, 06:56 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Independence MO
| | Re: Ok, had dremel and we'll see how much damage I did. Ok. I'll lower it. I noticed yesterday a chip off the flange on the exhaust. Wonderful.
__________________ _________________________________________________ It's a mathematical fact, 10 out of 8 people have trouble with fractions. Kings 70cc 3200+ miles. Now on a Schwinn Point Beach. (And say HI to my Dad, he works there in the Archives!) |
08-18-2008, 07:01 PM
| | Re: Ok, had dremel and we'll see how much damage I did. At 3100 miles, maybe the thing is getting tired? How's the compression?
08-18-2008, 07:07 PM
Originally Posted by Bikeguy Joe At 3100 miles, maybe the thing is getting tired? How's the compression? | Oh this motor is anything but tired. Before I did the porting thing and the exhaust it ran like a raped ape... And I mean the day before.
Ok, so let me get this right, I need to lower the clip... Maybe all the way down and work it upwards? The plug was dark brown suggesting to me, it was getting near being rich?
08-18-2008, 08:23 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: Ok, had dremel and we'll see how much damage I did. Lower the clip one notch at a time and try it, open the choke, mix fresh batch of gas/ oil, check for intake air leak....
08-19-2008, 11:20 PM
|  | Custom Builder / Dealer | | Join Date: Mar 2008 Location: Venice Beach, CA.
| | Re: Ok, had dremel and we'll see how much damage I did. Two of my customers bikes would run better with the choke half on.
I drilled the jets a little bigger, & it fixed 'em both!  |
08-23-2008, 09:16 PM
| | Re: Ok, had dremel and we'll see how much damage I did. Ok, today at the lowest notch I got a medium gray plug. Bike runs about the same....
I'm stumped.
08-24-2008, 01:33 AM
| | Re: Ok, had dremel and we'll see how much damage I did. Drill the jet... CAREFULLY! |
08-24-2008, 12:35 PM
Originally Posted by VENICE BOY Drill the jet... CAREFULLY! | Oh screw that. I'll just get it running as good as I can, and if the choke has to be 1/4 of the way on so be it. Thanks for all the help, but I'm done messing with this.
It's just for putting around the block every other weekend for 15 or 20 minutes, it's not a commuter....
Reason: you naughty boy and naughty words
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:41 AM. | | |
