Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
no head gasket
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. ok i know i suck at spelling lol any ways i heard that removing the head gasket u would get ...
Old 09-06-2009, 10:13 AM
Default no head gasket
i heard that removing the head gasket u would get more power in theory u would but is any one doing it
Old 09-06-2009, 10:20 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: no head gasket
Don't do it! You need the gasket to create a seal between the head & cylinder.
(you would never run your car without a head gasket!)
Old 09-06-2009, 10:23 AM
i work on cars for a living lol but i saw a guy here in ky said he did not have on and his was not leaking
Old 09-06-2009, 01:06 PM
i ran with no base gasket but i kept the head gasket. it will do the same thing, instead of a paper gasket you use permatex sealant,
<code>"isuck@code"</code>
Old 09-06-2009, 01:11 PM
thats what i thought but i thought the head gasket was thicker
Old 09-06-2009, 01:26 PM
If you remove the base gasket, it changes the port timing...
The correct way to increase compression, is to mill the head.
Old 09-06-2009, 01:32 PM
the head are the cylinder and how much could i go
GearNut's Avatar
Some engines do better with the port timing changed due to the base gasket being eliminated.
Others hate it. The manufacturing tolerances are not held to much of a standard, so each engine has it's own little quirks. It's fun to play around with these little engines and experiment with them.
  #9 (permalink)
Old 09-06-2009, 03:56 PM
your right there my friend, and it really tests your abilities as a hobbyist engine tuner. One misstep that you think is great can gernade the engine in a matter of days while some other small thing (like me removing the BG) will make it work like a charm for hundreds of abusive miles.....
i forgot to mention the port timing. I lowered mine because at BDC the pistons top was actually lower than the bottom of the exhaust port i wanted to get it all out. I had a little more bhang in the engines torque all around. Good stock mod.
On the new engine Im not sure if i want to do very much to it aside from a basic "tune" i dont expect arm ripping powerbands to be gotten reliably lol
  #10 (permalink)
Old 09-06-2009, 08:26 PM
i've been having problems with the head gasket leaking, everytime i start the engine when its fully cooled id get a little puff of air coming out hitting me on the leg that goes away after the engine runs for a few seconds. today i noticed a corner of the head gasket was ripped off, so i took out the gasket and used some of the grey rtv gasket maker stuff to seal it up. gonna try it out tommorow, i really hope it works.
