| | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | no head gasket Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. the biggest sucess i have had with creating a good powerband is with jetting, but i live at 7000 feet ...  | |
09-08-2009, 08:51 PM
| | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: ridgway colorado
| | Re: no head gasket the biggest sucess i have had with creating a good powerband is with jetting, but i live at 7000 feet once i figure this out maybe then its time for port mods, any other high altitude dudes out there? |
09-08-2009, 10:44 PM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2009 Location: So Cal
| | Re: no head gasket 7000 feet? Think really small fuel jet.
Somewhere I read a thread about a guy that stripped an end off of a bread bag twisty tie to expose the thin metal wire. He then removed his fuel jet from the carburetor and filled it up with solder using a butane torch to heat the jet. Before the solder hardened he stuck the wire in the solder, all the way through the jet, and held it there untill it cooled. Pull out the wire and you have a really small fuel jet. If it is too small you can use the wire like a ream and slowly enlarge the hole. |
09-08-2009, 10:48 PM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: Toronto, Ontario
| | Re: no head gasket this jetting stuff with the solder and the drilling a smaller hole, does it require a drill press or can it be done with a hand drill? |
09-08-2009, 10:57 PM
| | Re: no head gasket It is best done with a devise called a pin vice. It is sorta like a teeny hand drill you spin with your finger tips. Like winding up those cheap happy meal toys that hop around the table. I have seen these sold with rediculously small drill bits, all in a kit, at hobby stores.
About $8 to $10.
The bits are sooooo small that a regular chuck on a regular drill could not close up enough to grip the drill bit.
09-09-2009, 07:47 PM
| | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: Ontario
| | Re: no head gasket pin vice. cool. i just googled it.
<code>"isuck@code"</code> |
09-09-2009, 11:03 PM
| | Re: no head gasket heh me too. how do you make sure the hole is centered and true? |
09-09-2009, 11:52 PM
| | Re: no head gasket just an idea that bloomed from how we use jigs for drilling hole patterns at my job....
you could take a block of wood and drill a hole the diameter of the removed jet just deel enough to countersink it, and in the exat center of that hole a pinhole to the other side, where you make a hole countersunk for your pin vice  get where im goin?
09-10-2009, 11:04 PM
| | Re: no head gasket When you are drilling out a fuel jet, the hole can be off center a little bit. The gas will not care as it flows through it. |
09-28-2009, 02:37 AM
| | Motorized Bicycle Senior Member | | Join Date: Sep 2009 Location: Orlando
| | Re: no head gasket If you remove the base gasket you are lowering your port timing, which will almost always give you more low end, though you can at some point have your port timing to low/early.
On the other hand removing the head gasket does nothing but increase compression.
Use Threebond 1211 sealant to act as a head gasket, in either case. You also need to check your squish clearence before removing either base or head gasket. you should be running a minimum clearance of 0.7mm squish |
09-28-2009, 03:31 PM
| | Re: no head gasket Quote:
Originally Posted by Foximus Use Threebond 1211 sealant to act as a head gasket, in either case. You also need to check your squish clearence before removing either base or head gasket. you should be running a minimum clearance of 0.7mm squish | it is important to have some room for heat expansion of the piston... very important point.
however, on the other hand. the squish is almost non-existent on these heads lol
<code>"isuck@code"</code> | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:24 PM. | | | Sponsors
