I was on zoombicycles forum today while ordering another motor kit for my new moondog/(shorewood) and i found a thread about the new heads they sell for $12.95.
New Slant Head: Zoombicycles Motor Bicycle Engine Kits 80cc Slant Head Cylinder Cover (A-2B) | 14-Addons | 6-Parts and Accessories | RuiHong Enterprises Ltd..
Thread: zoom 80cc slant head upgrade evaluation - Zoombicycles Motorized Bicycle Engine Kit Forum.
I ended up ordering one of their new engine kits with this head already installed and ordered an extra head for my other motor. Ill let you guys know if it helps -Justin
UPDATE:
Purchase the following for successful installation*****:
(1) Slant Cylinder Head: Zoombicycles Motor Bicycle Gas Engine Kits 80cc Slant Head Cylinder Cover (A-2B) | 14-Addons | 6-Parts and Accessories | RuiHong Enterprises Ltd.
(1* or 2*/****) Head gasket(s): Zoombicycles Motor Bicycle Gas Engine Kits 80cc Head Gasket (A-3) | 10-Gaskets | 6-Parts and Accessories | RuiHong Enterprises Ltd.
OR Sick Bike Parts
(1*/**** or 2*/** or 3*/**/***) Cylinder Base Gasket(s): Zoombicycles Motor Bicycle Gas Engine Kits 80cc Cylinder Bottom End Gasket (A-7) | 10-Gaskets | 6-Parts and Accessories | RuiHong Enterprises Ltd.
*Most 69cc/80cc engines utilize m8 head studs, but the gaskets pictured show m6 diameter holes. The gasket holes may need enlarged for the larger studs...
**The reason for 2 or 3 cylinder base gaskets is some engines need the extra space to prevent the piston from hitting the head... Use only one gasket if you can get away with it!
***If you have modded your motor to reach extreme rpm (boost porting & other porting), I noticed my connecting rod is stretching enough to allow the piston to hit the head (power drops and slapping noise...) either add another base gasket (total of 3) or dont rev so high (10,000+rpm when it occurs for me). I didnt have any damage and it has happened a couple times (not intentionally), but i dont recommend it. BUT if concerned add another gasket or head gasket to make up the space...
****Jet silver motors currently sold by zoombicycles have the slant cylinder head preinstalled and they use 2 head gaskets and 1 base gasket to prevent the piston from hitting the head. I think that this raises the chance for a head gasket leak especially with the higher compression but so far i havent had any leaks on my stock jet silver motor so maybe this is another viable solution to the clearance issue, especially since this leaves the port timing unchanged.
*****Try at your own risk!! I cannot guarantee that it will work on absolutely every application (differences in manufacturing & tolerances etc.), I'm merely stating what worked for me and others. Have Fun!!!
UPDATE:
OR Sick Bike Parts
