Re: Need help with piston bearing Well, my big theory is that after awhile the crank might have stretched a little and
the upper crank arm was sliding side to side on the roller bearing itself.
The engine is an old powerking 80 and I'm trying to figure out how I can use the 12mm
pistons from DAX and just replace the 10mm wrist pin and bearing. I did a search and read
through a bunch of posts where other people had the same trouble and replaced the bearing
and added shims.
I guess I'll try that ... or give up and buy another engine, but no one has just the engine
in stock right now. Thanks
