| | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | muffler+drill=?? Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. ok so i got an engine kit,installed it, and it seemed sick...witch in my eyes was normal because ...  |
08-28-2009, 10:23 PM
|  | Motorized Bicycle Newbie | | Join Date: Jul 2009 Location: Petersburg,West va
| | muffler+drill=?? ok so i got an engine kit,installed it, and it seemed sick...witch in my eyes was normal because im 250 pounds...but i lost the cap off the end of the muffler what all xactly fell out is unknow to me...but i took a drill bit about 2 sizes smaller than a 1/4" drill bit...i drill 2 holes in the round peice,with the bolt welded on, that if i am correct is the catalac-coverter??i drill these 2 holes and got a big improvement in the stock muffler....but remeber i dont have thebottom cover on the muffler..and the bit size is 2 shades smaller than 1/4"  |
08-29-2009, 11:31 AM
| | Re: muffler+drill=?? Yep... you made the pipe flow a little better. (it's a very easy way to gain power!!)  |
08-29-2009, 02:17 PM
| | Re: muffler+drill=?? i rode it a little bit today...it runs great now, not much smoke and much more power |
08-30-2009, 05:50 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jan 2008 Location: Arizona Bullhead
| | Re: muffler+drill=?? Lots more noise to huh?
Motorized bicyclist
08-31-2009, 12:51 AM
| | Motorized Bicycle Member | | Join Date: Apr 2009 Location: Portland, OR
| | Re: muffler+drill=?? do you have pics? |
10-29-2009, 08:04 PM
|  | Motorized Bicycle Newbie | | Join Date: Oct 2009 Location: Muskegon, Michigan
| | Re: muffler+drill=?? i want to see pics |
10-29-2009, 08:18 PM
| | Re: muffler+drill=?? i kinda did the same thing, but i don't have pics, either.
if you take the screw out of the bottom, the cap pulls out with a pipe welded to it. i drilled 5 or six little holes thru the pipe, so it looks like a flute i also drilled a few 1/4 holes in the end cap. installed it all back together, and used a pair of vice grips to tighten up the bottom screw.
it's actually QUIETER than stock, and it got rid of some of that ting ting tinny sound.
seems faster, too. |
10-29-2009, 08:44 PM
| | Re: muffler+drill=?? With the Raw kits, you can just remove the exaust pipe end cap, & saw off the inside of the stinger tube & put it back on!! (still quiet, & lots of power!!!)  |
10-31-2009, 12:15 AM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: Utah
| | Re: muffler+drill=?? I drilled a 1/4 inch hole in the end of the tube that has the bolt welded to it. pretty happy with the results: Good: top end increased significantly, higher revs and more speed, pulls hills a lot easier and faster. Bad: seem to have lost the bottom end... gutless on take off. I'd rather go faster once I'm going, so I'm fine with it. |
10-31-2009, 04:21 AM
| | Re: muffler+drill=?? I respect that it's an easy and cheap (read "free" lol) modification, I even did it myself heh, but TBH it is just a work-around, yer not really "gaining" any power - yer just allowing the engine to breath a little better, allowing it to use the power it does have.
That's fine of course - but if you really want yer motor to not only run better but to get an actual gain in performance above stock - try the expansion chamber from Sick Bike Parts: Sick Bike Parts expansion chamber kit
Granted - it's not free lol, but it's worth every penny
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:30 PM. | | | Sponsors
