Re: Motor sprocket change I run a 34T from Andy's shop. For my town it works killer. I can do 30-35 mph at around 5000rpm on flat ground...cruising! If I want I can go full out 6500 rpm and hit 40mph no problem. Steep hills aren't an option, though, but I can still pedal assist up some medium grades. Also, you need to go a bit faster to start, and pedal into the engines comfort zone, or the clutch won't last too long. I'm a pretty big guy (6'4" 230lbs) and the 34T is a fun one. |
