Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Motor sprocket change
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. HI Dominate, FWIW - I have sold a lot of 27T sprockets to people running a 20" wheel....Since you ...
  #11 (permalink)
Old 10-11-2008, 04:10 PM
Andyinchville1's Avatar
Manufacturer/Dealer
Default Re: Motor sprocket change
HI Dominate,
FWIW - I have sold a lot of 27T sprockets to people running a 20" wheel....Since you mentioned you have a 22" wheel the equivalent would be a 29T in your case...
Overall, this would be the same as a 26" wheel running a 34T sprocket.
Hope this helps you
Andrew
Sprockets now available in 9 anodized colors!
http://www.myspace.com/kingssalesandservice
http://www.youtube.com/watch?v=-zyU8n41f2c
  #12 (permalink)
Old 10-11-2008, 04:15 PM
Manufacturer/Dealer
HI,
I forgot to mention....since you were looking at maximum top speeds....there will eventually be a point of diminishing returns as you go to a smaller and smaller rear sprocket (eventually hills and aerodynamic drag) won't allow you to operate the bike in a reasonable manner....We can go as low as 18T (From 18T to about 26T it will require a disc hub mount)...
THAT should allow for some insane speed runs on level to slightly down hills!!
The smallest sprocket I have sold so far for the motorized bikes is a 27T for use on a 20" wheel....Maybe you'll be the first to go smaller?
Andrew
  #13 (permalink)
Old 10-11-2008, 10:51 PM
Motorized Bicycle Apprentice
Originally Posted by Andyinchville1 View Post
HI Dominate,
Andrew
Is there something wrong with a 22" measurement? Maybe I measured my wheel wrong..is there a specific way to do it or just from 1 edge of the wheel to the other? Either way I think I'll go with the 29T sprocket.
  #14 (permalink)
Old 10-14-2008, 06:56 AM
im not sure how you guys are getting such good results with the 36T. i have 2 of them that i replaced with 27t sprockets from andy. the 27t allows me to cruise at a non-meditative speed and not scream the engine. as for using a 40, 44 and on up tooth, i would have given up riding if i had to deal with that sort of vibration generating slug. hard on guitar playnig tendons. i would use the 44 and up on a motorized wheel barrow.
"You must cultivate the feeling that a warrior needs nothing"-don juan
  #15 (permalink)
Old 10-14-2008, 07:02 AM
22 inch wheel??
  #16 (permalink)
Old 10-14-2008, 05:20 PM
really, is 22 a weird measurement? I'm not sure if I measured correctly. Is there a proper way to measure the wheel? Because I just went from 1 side to the other o.O Please help Maybe I have 20" wheel
  #17 (permalink)
Old 10-15-2008, 01:23 AM
fairracing31's Avatar
Here is a link, hope its some help
How to measure your bicycle wheels
  #18 (permalink)
Old 10-15-2008, 01:57 AM
Oh I see. Thank you. I guess I have a 24" wheel then.
Advertisers
