| | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | motor bicycle Wheel balancing Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. HI All,
Never really thought about wheel balance until I was looking at one of my bikes (engine free indoor ...  |
01-22-2008, 12:34 AM
|  | Manufacturer/Dealer | | Join Date: Dec 2007 Location: Charlottesville, VA
| | motor bicycle Wheel balancing HI All,
Never really thought about wheel balance until I was looking at one of my bikes (engine free indoor bike) and noticed it had one of those large spoke mounted reflectors in the wheel.
Just out of curiosity I took off that reflector and weighed it....Turns out it weighed nearly 3 ounces!.....And since it was located fairly close to the rim itself I thought that was a fairly heavy wight to be so far off center.....In an attempt to partially offset some of the weight of the reflector, I did take the trouble to remount it opposite of the valve stem (every bit helps huh?)..While I have not yet personally taken the time to see how far off balance the wheel is (I will when it warms up a little since all my motorized bikes live outside in the shed Brrrr)....I was wondering if any of you out there actually too the time to balance your wheels/tires?.....In thinking about it I will probably do so
shortly because as we approach top speeds of 35+ MPH it may become important (I'll probably use stick on automotive balance weights).
What do you think?
Andrew |
01-22-2008, 01:12 AM
| | Motorized Bicycle Newbie | | Join Date: Jan 2008 Location: SoCal
| | Re: Wheel balancing Balancing will reduce vibration at speeds over 28mph in my experience.
However, I build my own wheels to be true to + or - .005" total run out and use quality tires with reflective stripes so no heavy reflectors are used. Balance has not been an issue. I use Slime tubes f&r and on the rear a Mr. Tuffy tire liner. My top speed is 30mph.
Mounting the reflector about halfway between rim and hub makes a real improvement. Adding another oppisite also helps. Presta valve stems are lighter than Shrader type. |
01-22-2008, 07:20 PM
| | Re: Wheel balancing HI Pete,
Good idea about getting another reflector to balance out the original one.....Since it is an older bike I'll have to look for a similar one or heck I may pop for 4 new ones!....Supposed to be about 40 tomorrow so I may come out of hibernation and balance all the bikes.
Andrew |
01-24-2008, 05:57 PM
| | Re: Wheel balancing I always balance my wheels by wrapping the spokes near the rim with solder. I made a balancing table for the wheels. |
01-24-2008, 05:58 PM
| | Re: Wheel balancing Oh yeah, you can buy stick on lead weights at the sporting good store (used for golf clubs I guess). |
01-27-2008, 07:35 AM
| | Administrator (aka CaribbeanCruiser) | | Join Date: Dec 2007 Location: St. Croix US Virgin Islands
| | Re: Wheel balancing another thing to put on the list that needs to be done. a lot of times things are overlooked when trying to get the best performance out of you motorized bicycle |
01-27-2008, 07:59 AM
| | Re: Wheel balancing How about putting zip ties at all spoke crosses?
Works nicely to "firm up" the wheels. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:56 PM. | | | Sponsors
