Originally Posted by motorhead419 I have a 25 pilot jet in my 18 mikuni and a 75 main jet. Needle in the middle. You have to make a bushing for the intake manifold as the mikuni is bigger there. |
Motorhead is correct, you will have to make a sleeve or bushing to adapt the
larger diameter carb intake to fit your manifold. I made mine out of a piece of
3/4' PVC pipe. I cut it about 3/8' long and then sawed a 1/8th slot in the sleeve,
so that it could tighten down on the manifold. It's going to be a trial and error
fit, but it works great, plus it insulates the carb from high heat absorption.
I also have a #25 pilot jet, the needle clip is on the top notch and I'm running
a #65 main jet. It
IS the right carb for these engines
