Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
loud and fast
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. 2-strokes run best with the *proper* back-pressure. I've run the bike with just a 4-inch pipe ...
  #11 (permalink)
Old 08-28-2008, 05:30 PM
jasonh's Avatar
Default Re: loud and fast
I've run the bike with just a 4-inch pipe off of the head...it's WAY too loud. 20 min of that will give you a nice headache, and lots of nasty looks from people.
  #12 (permalink)
Old 08-28-2008, 10:31 PM
rickdiculous's Avatar
Motorized Bicycle Apprentice
so i burned up the nieghborhood today. after the work i noticed a bid difference. i still have some spots of "four cycling" but can usually power through them. i'm giving these mods a big thumbs up. try it yo!
  #13 (permalink)
Old 08-28-2008, 11:03 PM
misteright1_99's Avatar
Originally Posted by Jimmy View Post
Hey guys im new to the site and I was wondering, I know removing the baffle elimanate back pressure but isnt some back pressure necessary for a two stroke to work properly
Backpressure to a point Recharges the spent unburned fuel/ air back into the cylinder for a supercharge effect, return pulse. Thats why when installing an expansion chamber the design and length are best to be matched to the engine size. With less backflow you will get a higher flow, so you may have to change the needle clip setting, watch your spark plug for lean condition.
  #14 (permalink)
Old 08-29-2008, 08:23 PM
running without muffler or baffle do lean the piston and the sparkplug so you will use your piston . ive tried it ...
  #15 (permalink)
Old 09-08-2008, 07:49 PM
Biker Mike's Avatar
Originally Posted by NEAT TIMES View Post
andrew, could you put a see thru oven door on the muffler, i could cook meals while on the road!!!
Gives new meaning to "Meals on wheels". ROTFLMO
  #16 (permalink)
Old 09-09-2008, 02:53 AM
I do service and maintence on these motors and I've noticed
on some engines the lack of back pressure due to no or half a baffle
wrecks the piston rings.
  #17 (permalink)
Old 11-15-2008, 05:24 PM
ibcnya's Avatar
"four cycling" What is this? can someone explain it?
  #18 (permalink)
Old 11-16-2008, 06:35 PM
Bikeguy Joe's Avatar
MODERATOR
It's when the engine is too rich and fires every other time...four stroking.
  #19 (permalink)
Old 11-16-2008, 08:42 PM
ibcnya's Avatar
Like.....if my carb needle was set on the bottom slot kinda of rich? I think I may have solved my issue tonight. How it got set on the bottom slot, I have no idea, but it was.
  #20 (permalink)
Old 11-17-2008, 05:30 AM
MODERATOR
Yes, just like that.
Advertisers
