Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Killer Spark plug & Oil
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. I found the best spark plug what a difference in every way it's made by Denso IRIDIUM POWER IWF20 ...
Old 08-14-2009, 10:36 AM
Hot Wheels's Avatar
Default Killer Spark plug & Oil
with opti-2 oil, I can start my bikes by just walking and pop out the clutch and they fires right up and run so smooth. If you go to Denso's web site the plugs are 11.99 or on amazon you can find them for 8.49. the first plug I put in my idle went way up from where it was set, I'm sure it was because the plug was so much better.
Iridium is a precious metal that is 6 times harder and 8 times stronger than platinum, it has a 1,200 degrees (F) higher melting point than platinum and conducts electricity better. This makes it possible to create the finest wire center electrode ever. Prior till now, the technology did not exist to machine and bond iridium on a spark plug electrode (at least in a cost effective manner). However, Denso's superior technology allows them to laser weld an 0.4mm iridium center electrode on the Iridium Power and Iridium Racing spark plugs. The strength, hardness and high melting point of iridium makes it very well suited for a fine wire plug.
Old 10-23-2009, 09:21 PM
Default Re: Killer Spark plug & Oil
The plug is on sale at JC Whitney for $7.99 regular $9.99...does this fit a grubee 48cc?
Iridium Power Spark Plugs - JCWhitney
Old 10-23-2009, 10:44 PM
Hot Wheels's Avatar
I'm not sure, if your willing to try it, buy one and check the length with the one you have now, if it's not longer it should work. you will be amazed of the difference.
Old 10-24-2009, 01:54 AM
i have iridium's in my car, and yes they are quite nice.
