| | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | intake port and intake tube Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. will this work???
ok if i take off the intake tube from the port and remove the stock gasket..and ...  | |
08-28-2009, 10:27 PM
|  | Motorized Bicycle Newbie | | Join Date: Jul 2009 Location: Petersburg,West va
| | intake port and intake tube will this work???
ok if i take off the intake tube from the port and remove the stock gasket..and put ultra grey gasket maker on it, will it improve preformance? i was told it might help..just double checking with people who know what im talking about, i was told the stock gasket covers some of the port??  |
08-29-2009, 03:00 AM
| | Motorized Bicycle Elite Member | | Join Date: Feb 2009 Location: australia
| | Re: intake port and intake tube Quote:
Originally Posted by Z00mz00m will this work???
ok if i take off the intake tube from the port and remove the stock gasket..and put ultra grey gasket maker on it, will it improve preformance? i was told it might help..just double checking with people who know what im talking about, i was told the stock gasket covers some of the port??  | Nah just cut the portion off that covers the port. |
08-29-2009, 06:09 AM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2008 Location: Lagrange Indiana
| | Re: intake port and intake tube I had issues with a reasonably new motor . What your asking did help mine start easier and run better. |
08-29-2009, 07:59 AM
| | Re: intake port and intake tube Mark the stock gasket and trim it, then smear a thin coat of the sealer on both sides and re-install.
08-29-2009, 02:18 PM
| | Re: intake port and intake tube i completely removed the gasket..put a gas &oil resistant gasket maker on it,,,.it seems to help a lilttle bit on starting but not much more power...i did a post on my muffler witch help very much |
08-30-2009, 12:13 AM
| | Re: intake port and intake tube if that works for you |
08-30-2009, 12:20 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: tucson
| | Re: intake port and intake tube a couple days after you put it on with silicone, you can take it off and see clearly where either needs to be match ported. |
08-30-2009, 01:22 AM
| | Re: intake port and intake tube squeeze two pieces of steel together with silicone on it and see where it goes? these surfaces are ment to be used with a GASKET that silicone or gasket maker is doing the same thing as a std gasket does impede flow. |
08-30-2009, 05:40 AM
| | Re: intake port and intake tube The only impeded flow I have ,is when
I passed 50 years old and nature calls . If you read the directions on the RTV sealer and follow them you will not impede the flow enough to make a differance unless you are in to racing . Excess use of this product isn't a good thing . When you tighten the bolts you have already let the small bead of sealer set for 1 hour to harden. That is how you avoid the oooze factor . As I said before read the directions . |
08-30-2009, 06:51 AM
| | Re: intake port and intake tube [quote=leftywoody;103143]The only impeded flow I have ,is when
I passed 50 years old and nature calls . If you read the directions on the RTV sealer and follow them you will not impede the flow enough to make a differance unless you are in to racing . Excess use of this product isn't a good thing . When you tighten the bolts you have already let the small bead of sealer set for 1 hour to harden. That is how you avoid the oooze factor . As I said before read the directions .[/QUOT
i use a gasket | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 02:10 PM. | | | Sponsors
