Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
I have a dremel, what can I do with it?
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. Actually I have a couple of them. With lots of attachments. I was looking at my chromed metal intake, and ...
Old 08-10-2008, 03:54 PM
Motoschwinn's Avatar
Default I have a dremel, what can I do with it?
Actually I have a couple of them. With lots of attachments. I was looking at my chromed metal intake, and my exhaust. Make it simple for me, what can I do with this that will make my bike run better? Looks to me like I should just make things match up better?
It's a mathematical fact, 10 out of 8 people have trouble with fractions.
Kings 70cc 3200+ miles. Now on a Schwinn Point Beach.
When in Kansas City Missouri visit the only national WWI museum
www.libertymemorialmuseum.org
(And say HI to my Dad, he works there in the Archives!)
Old 08-10-2008, 05:27 PM
pedalpower's Avatar
Default Re: I have a dremel, what can I do with it?
3100+ miles, what haven't you done? I assume you've bezeled the exhaust header to match the exhaust port opening? and hone out the gasket to match up everything.
hmmm, dremel, you can't tinker without one in the toolbox.
and of course, the most important safety item, these...safety glasses.
Old 08-10-2008, 05:46 PM
when i began building i bought allthread and made engine studs with it. i also ported exhaust and modified the drum brake arm and some pull brake mounting parts. also shorteded chain.
Old 08-10-2008, 05:50 PM
No, I haven't done anything. I'm lucky I have one of the coveted Kings early motors. Completely stock other than the plug wire and NGK plug and new exhaust.
Old 08-10-2008, 10:17 PM
eDJ's Avatar
eDJ eDJ is offline
Long ago when I first got into 2 cycle bikes one guy I met had been at it a few years. He even worked in the summers of his high school year as a tech at a Kawasaki shop. I was a bit older than him but I learned loads from what he showed me.
The Dremel or any of the knock offs of it are handy. There are battery powered ones and swivel head models but his was a ball bearing high speed job. He had grown rather handy with it too. It seems he started with cycle magazines that showed how to tweek the Japanese piston port bikes which he was able to buy cheap as they were older.
He showed me an article on cylinders that detailed sizing and matching of ports and the photos showed the transfer ports and the other ports that were important to work on. It seemed the production finish was rather imprecise in those days and the article showed showed pictures of using a new piston to hold up in the bore of the cylinder (which was off the engine) and using a scrib to mark the bottom of the ports even with the lowest port and again the same way at the top by placing the piston down from the top of the cylinder. This used the piston edge like a straight edge to align the tops and bottoms of the ports exactly even. Then the Dremel tool was used to grind to the mariings and then relieve the edge so the ring wouldn't get caught on it. (basically rounding the edges of the ports outward away from the cylinder wall)
The reasoning was that all the ports would open or close at the same time as the edge of the piston dropped below the edge of the ports or rose above them. There were some tapered guides just behind the carb leading into the cylinder that he would smooth up and even whittle down a bit. Thus fuel air entry flow would be more streamlined. It's already been mentioned to match the intake ports, gasketts, and manifold to the same size so all is a smooth transition.
My buddy even had a half dozen new spark plugs he would torque into the head (which was off the engine) to check and inspect each one to see if any of the reach extended into the chamber. I actually saw him touch up a few and smooth them even with the head. Some of his bikes had rotary valves and some even had reed valves. With those he would shave the rotary valve back on one or both sides with his Dremel tool. I don't know if the Chinese are offering this technology yet, or just staying with the cheap and dirty little piston port 2 strokes. Reed valves seemed to be adjusted with a feeler gage to where they were tweeked to his satisfaction.
I used to go with him to the motorcycle drag races and help get the three bikes he raced on and off the trailer. He had this "OLD" Kawasaki Big Horn one cylinder dirt bike that he had installed a big bore piston kit on and changed the gearing. This thing looked like it had been drug out of a dump it looked so bad.....but he had smoothed up the ports, worked with the rotary valve and and a "torque tube" expansion chamber. He would run against Honda four cylinder bikes and beat them consistantly by a foot or two.....but he won. Talk about some angry Honda owners and a laughing crowd of spectators. I mean I don't think a self respecting dog would have chased after his old Kawasaki. But all the tech tweeks were on the inside where nobody would expect them when they looked at the outside.
But all this was back in the early eighties when I was first learning about this stuff. That's when I learned how much difference a Dremel tool could make.
Give this page a look.
Engine Modifications
Advertisers
