| Sponsors
| | | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | HT Main Jet Size? Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. I just use a soldering iron, seems to get it hot enough to plug the hole. I try not to ...  | |
09-13-2008, 12:19 AM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Bellingham, WA
| | Re: HT Main Jet Size? I just use a soldering iron, seems to get it hot enough to plug the hole. I try not to heat it up too much for fear of getting too good of flow and dripping solder out the other side. Here is the drill set I bought. Has all the good ones for our 2 strokes. 25pc. Carburetor Drill Kit |
09-13-2008, 12:39 AM
| | Re: HT Main Jet Size? |
09-13-2008, 12:44 AM
| | Re: HT Main Jet Size? Now where is the adventure in just buying something?  |
09-13-2008, 12:54 AM
| | Re: HT Main Jet Size? Quote:
Originally Posted by Ghost0 Now where is the adventure in just buying something?  | If I had any more adventure in my life right now I'd need Cialis |
09-13-2008, 08:54 AM
| | Re: HT Main Jet Size? I think the statement should be "If I had more excitement in my life now I WOULDN'T need Cialis."
Uh, not that I do mind you, I uh, nevermind this is going downhill fast....
09-13-2008, 09:22 AM
| | Re: HT Main Jet Size? Mine is as I meant it......
OK OK - I didn't have all the time to solder and I'm dubious of the actual size and shape of the holes home drilled, but if it works, it really doesn't matter. |
09-13-2008, 11:03 PM
| | Master Motorized Bicycle Builder | | Join Date: Sep 2008 Location: black mountain NC
| | Re: HT Main Jet Size? yeah my first playing here is with solder & torch tip cleaners so a drill would be much more precise :-)
take care
JAK |
09-15-2008, 11:41 AM
| | Motorized Bicycle Builder | | Join Date: Aug 2008
Originally Posted by Ghost0 I just use a soldering iron, seems to get it hot enough to plug the hole. I try not to heat it up too much for fear of getting too good of flow and dripping solder out the other side. Here is the drill set I bought. Has all the good ones for our 2 strokes. 25pc. Carburetor Drill Kit | Those bits seem funny. Looking at the picture, as the numbers get bigger the bit gets smaller. Like wire size... 10ga is much bigger than 22ga.
On the jet sizes, shouldn't the bigger number represent a larger hole ? |
09-15-2008, 12:14 PM
| | Re: HT Main Jet Size? Drill number size as you suggest are like wire or steel sizes. Larger number is smaller and smaller number is larger. Here is a drill size chart for reference.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:59 AM. | | |
