| Sponsors
| | | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | HT Main Jet Size? Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. Originally Posted by misteright1_99
#68 Drill = .031 Pablo
Thanks - saved me the hassle of searching the net, getting out Machinery' ...  | |
06-25-2008, 10:07 AM
| | Re: HT Main Jet Size? Quote:
Originally Posted by misteright1_99 #68 Drill = .031 Pablo | Thanks - saved me the hassle of searching the net, getting out Machinery' s handbook, finding a wallchart....   |
06-25-2008, 10:57 PM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Corpus Christi, Texas
| | Re: HT Main Jet Size? The rubber O ring that should be there does not change the gas to air mixture. The AIR needle does. The .48cc is about 23-30. Seventy cc about 30-36 at most. One to, One & One half turns. I run 140 mains in my goldwing but I'm pushin' 6 carbs.
No matter where you go, or what you do, there Ya' are! |
06-26-2008, 08:17 AM
| | Re: HT Main Jet Size? These carbs don't have an air needle.
08-14-2008, 08:17 PM
|  | Motorized Bicycle Apprentice | | Join Date: Aug 2008 Location: Huntington Beach, CA
| | Re: HT Main Jet Size? My HT80 ran too rich on the stock jet after some 150 mile break-in. I soldered up the stock jet and began with a .4mm(way too lean) I settled on the .6mm (.023) with the needle clip is at the top. I getting a good burn on the plug and picked up about 2mph.
I am running a 32:1 mixture now using Belray MC-1 synthetic. (As a matter of interest the Powerking 80cc actually measures 69.3cc.) |
09-08-2008, 04:07 PM
| | Motorized Bicycle Apprentice | | Join Date: Sep 2008 Location: Seattle
| | Re: HT Main Jet Size? Hi, i am new to this forum and i have recently drilled my mainjet out waaay too big. now i would like to know how to solder up the hole and redrill it. do i need brass solder? or what? thanks! |
09-08-2008, 04:45 PM
| | Re: HT Main Jet Size? this may be a dumb question but i went to the dellorto site but all the jets were listed as 5mm, how do i know what size the orafice is of those jets (.7mm,etc)?
thanks. |
09-08-2008, 04:49 PM
Originally Posted by wizzizer this may be a dumb question but i went to the dellorto site but all the jets were listed as 5mm, how do i know what size the orafice is of those jets (.7mm,etc)?
thanks. | I know what you mean. It's by the part # - just stick your own decimal point in. #70 is .70 ,#65 is .65, etc |
09-08-2008, 04:50 PM
| | Re: HT Main Jet Size? I have never heard of a jet being soldered with any luck. New one is my guess.
09-08-2008, 07:02 PM
| | Re: HT Main Jet Size? i read in another post that some were drilling and soldering and redrilling to try to find the right size so i thought it was common, oh well. i just ordered a few from dellorto anyway.
thanks guys! |
09-12-2008, 07:11 PM
| | Re: HT Main Jet Size? I use a propane torch and electrical solder, I also use a resin type flux when soldering. Don't need much heat use needle nose pliers to hold jet in the fire then tough the solder to the hole and it wil flow into the hole very little solder is needed, to drill the hole I use a pin vice to with micro drill bits to drill my main jets by hand with the main jet mounted in a vice. works for me with no problems. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:50 AM. | | |
