| Sponsors
| | | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | hT KIT MODS? Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. yO... are all these ht chinese kit motor mods gonna apply to a japanese 2stroke engine? or has all this ...  |
08-07-2008, 05:26 PM
| | Motorized Bicycle Apprentice | | Join Date: Jul 2008 Location: spring tx horth suburb of houston
| | hT KIT MODS? yO... are all these ht chinese kit motor mods gonna apply to a japanese 2stroke engine? or has all this stuff been sorted out already? JB |
08-07-2008, 08:45 PM
| | Re: hT KIT MODS? They are crude, piston ported two strokes, hot rodding them like they did in the 50's applies.
08-08-2008, 06:19 AM
| | Re: hT KIT MODS? thanks BGJ. how does hp filter upgraded carb and stalker exhaust sound for a 41cc mitsu? do you think the plug wire trick or lightened flywheel would be beneficial? |
08-08-2008, 08:19 AM
| | Re: hT KIT MODS? Well, A good plug wire help the chinbna engines a lot, and so does opening up the intake/cleaning the ports up, as long as you adjust the mixture accordingly.
They don't have a flywheel to be lightened so to speak, and I don't have an knowledge of the stalker exhaust, so I can't comment on that.
I will say these engines respond to all the regular basic hot rodding tricks.
Reliability goes down as power goes up.
08-10-2008, 05:43 PM
|  | Motorized Bicycle Builder | | Join Date: Aug 2008
| | Re: hT KIT MODS? well, I got bored ( I hate that). walked around Home Depot until I saw an empty quart can and thought:
so:  or
just trying to get a little more airflow, without doing a boost bottle.
jon |
08-10-2008, 06:38 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Independence MO
| | Re: hT KIT MODS? Quote:
Originally Posted by Bikeguy Joe Well, A good plug wire help the chinbna engines a lot, and so does opening up the intake/cleaning the ports up, as long as you adjust the mixture accordingly.
Reliability goes down as power goes up. | So.... dealing with a numb skull like me, I'm cleaning up the intake manifold that I have, HOW or what setting would I want to put the clip at?
__________________ _________________________________________________ It's a mathematical fact, 10 out of 8 people have trouble with fractions. Kings 70cc 3200+ miles. Now on a Schwinn Point Beach. (And say HI to my Dad, he works there in the Archives!) |
08-10-2008, 06:58 PM
Originally Posted by Motoschwinn So.... dealing with a numb skull like me, I'm cleaning up the intake manifold that I have, HOW or what setting would I want to put the clip at? | how are you cleaning up the intake manifold. I've read that the interior should remain alittle rough for atomization. |
08-10-2008, 07:42 PM
Originally Posted by pedalpower how are you cleaning up the intake manifold. I've read that the interior should remain alittle rough for atomization. | On the steel manifold I have, the weld was about 1/8" off. So I'm cleaning that up. If you stuck your finger in, the one side you could feel the metal protruding I've just ground that off. I have the older style cast manifold on the bike currently. I hope that makes sense.
08-10-2008, 08:30 PM
| | Re: hT KIT MODS? Cleaning up the intake will not likely need a clip adjustment unless accompanied by an mod to the air filter cover.
You may see slightly higher revs, or a little better pull in the mid to upper end of the rpm range.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:58 PM. | | |
