Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
how much HP on the HT engine
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. even with mods I have done to mine I doubt Im getting 5HP out of my engine I doubt they ...
Old 10-19-2008, 09:33 PM
Default how much HP on the HT engine
I doubt they are 2 HP stock
I think on my engine Ive helped the HP far more then the torque which is just moving the torque up higher into the RPMs
I can climb hills much faster but have to have the RPMs up higher to do so whereas before it would slow down to the torque spot
Im going to try an 18mm carb which I think will flatten out the bottom even more but add more to the top In the end a 15mm chainsaw carb with a 12mm venturi might do the best across the board
Im gona run down to the local chansaw shop tommarrow
the owner says he has some vintage carbs which will probably work well
have a great week
JAK
Old 10-20-2008, 03:13 PM
Motorized Bicycle Apprentice
Default Re: how much HP on the HT engine
Did you get to oversize or enlarge the intake and exhaust on your engine? I have not doned yet but after that, I'm going to try a mikuni 18mm carb. I'm just a beguinner on this engine. I will try to get the most power out of it. If you have any other ideas how to get more power please let me know. Kiko. Have a good one.
Advertisers
