| | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | How fast can your 80cc really go? Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. im hitting 35mph(56kph),with a 44t ,stock 48cc stock carb stock muff,i using regular cheap gas and reg ...  | |
06-21-2009, 10:31 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: upstate NY
| | Re: How fast can your 80cc really go? im hitting 35mph(56kph),with a 44t ,stock 48cc stock carb stock muff,i using regular cheap gas and reg cheap 2-stroke oil at 20:1.
06-21-2009, 11:01 PM
| | Motorized Bicycle Elite Member | | Join Date: Nov 2008 Location: Colorado
| | Re: How fast can your 80cc really go? Bike1: 24mph 50 tooth rear sprocket, stock head, stock exhaust
Bike 2: 38 mph per GPS SBP shifter kit, 7speeds, high compression head
Bike 3: 40+ mph SBP shifter kit, 7 speeds, high high compression head, TUNED PIPE. It keeps pulling at 40mph but that's way above my personal comfort level. |
06-28-2009, 03:31 AM
| | Motorized Bicycle Senior Member | | Join Date: Feb 2009 Location: Billings, Montana
| | Re: How fast can your 80cc really go? I hit 37.2mph today on the flat with a pretty much stock 44t sprocket set-up. Only mods done on this bike is leaning the main jet and matching the intake and exhaust pipe to the cylinder. It must be the flames that make it fast! |
06-28-2009, 10:14 AM
|  | Motorized Bicycle Senior Member | | Join Date: Jun 2009 Location: Portugal
| | Re: How fast can your 80cc really go? Witch my motorized bike called bina i hit 58,23Kph (36.2MPH) with 44T sprocket.
60cc all stuff stock  |
06-28-2009, 01:42 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2009 Location: Maine
| | Re: How fast can your 80cc really go? I got mine running well last night, so I took my GPS for a ride. I hit 35 on my stock 44t sprocket :O but quickly slowed down. But I live with a lot of hills, that flat section is about the only flatish section of road for miles. So I'm more concerned with uphill speed than flat speed. I'm waiting on a slant head, so that should greatly improve uphill speed. |
06-28-2009, 03:23 PM
| | Re: How fast can your 80cc really go? DanialMaia, Do I see a triple tree fork with suspension? I want! |
06-28-2009, 03:38 PM
| | Motorized Bicycle Newbie | | Join Date: Jan 2009 Location: michigan
| | Re: How fast can your 80cc really go? I had my first one up to 34mph before it blew up. second one tops out at 23mph same set up, engine was replaced under warranty 12 mph slower than the first one. |
06-28-2009, 07:29 PM
| | Re: How fast can your 80cc really go? Quote:
Originally Posted by Masterm222 DanialMaia, Do I see a triple tree fork with suspension? I want! | This front fork is not "that pretty thing"  I bought this motorized bike just as you see  |
06-30-2009, 04:56 PM
| | Motorized Bicycle Elite Member | | Join Date: Aug 2008
| | Respuesta: How fast can your 80cc really go? i should make a correction to mine..
i am actually making 20 WOT 22 maxing it out for a while......with a 44t and stock exhaust....im going to lower the sprocket to a 40T and a leaner jet...lets see what i can do..hope to get 30 wot 20 cruise....
cant really believe people are going 35 on a 44t....but thats me |
06-30-2009, 09:09 PM
| | Re: How fast can your 80cc really go? If you are only getting 20-22 max your bike is not running right in my opinion. There is a long steep hill to climb to get to the airport from down town Billings and I climbed it at a steady 19.6 with 44t. Leaner main jet was only mod from bone stock out of box. If you can't find jets it is easy to re-size them smaller yourself. All my jets are "custom sized" by soldering shut then drilling to the smallest needle drill bit I could find(get hand set at hobby shop) I then size them with a welding tip cleaner that can be bought at a auto parts store. Tip cleaner is marked for size, my drill bits are not. Make sure you test the size of your jet before you solder so you know your starting point. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 08:37 PM. | | | Sponsors
