Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Homemade Reed Kit
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. That would be for the diaphragm fuel pump in the walbro carb. It needs engine pulse to work the diaphragm , ...
LinkBack (2) Thread Tools Display Modes
  #11 (permalink)
Old 05-25-2009, 02:22 PM
goat herder's Avatar
Default Re: Homemade Reed Kit
That would be for the diaphragm fuel pump in the walbro carb. It needs engine pulse to work the diaphragm , which in turn makes the internal path ways of the pumper carb work correctly to the jets.
One can do anything you set there mind to.... Do a good thing...
  #12 (permalink)
Old 10-13-2009, 09:42 PM
how much for you to make one of these for my ht? also, what model was the walbro- it looked like the 167a but thats way to small for a motorized bike engine.
  #13 (permalink)
Old 10-14-2009, 02:52 AM
you took your pulse line off the base of your transfer port...
Bold...
  #14 (permalink)
Old 10-14-2009, 10:39 PM
ohh i know what carb. didnt read closely enough. the hda 63. just ordered it, ill do the same thing as you but with a 4 petal reed valve once i get a little more money to order it. nice reeds are a bit expensive... for a 4 petal carbon fiber reed its like 70 bucks!
  #15 (permalink)
Old 11-04-2009, 08:39 AM
Anyone know if theyre are known issues (blowing crank seals) when adding reeds with just port matching and polishing?
  #16 (permalink)
Old 11-05-2009, 11:41 AM
DanielMaia's Avatar
How did you make that hole to the pulse of the carb? You drilled a hole directly to the motor? And if you one day put back the old carb?
thanks
  #17 (permalink)
Old 11-10-2009, 02:45 PM
europorsche914's Avatar
hey guys i dont even have that motor anymore... i had trouble tuning it but if someones interested in buyin my old setup pm me! -justin
50cc Morini S6-T 5.8hp,
44 tooth sprocket, Early 1990's Diamondback Frame, 26" WTB FX28 Wheels w/ Shimano XT Hubs,
Dellorto PHBG Race Edition 19mm Carburetor, 4 Valve Reed Intake (combined adds ~2hp),
Homemade Expansion Chamber, Homemade Steel Pack Muffler, Homemade 1.6 gallon Rear Gas Tanks
TOP SPEED: 54.0 MPH (not gps tested yet)
  #18 (permalink)
Old 11-11-2009, 03:32 PM
DanielMaia's Avatar
Look, how did you put the pulse to the carb? You drilled a hole directly to the crankcase?
  #19 (permalink)
Old 11-11-2009, 08:07 PM
If he wants to go back to the original carb he can just put a screw in the old hole that was drilled into the motor. No big deal.
  #20 (permalink)
Old 11-11-2009, 08:53 PM
Yea i drilled a hole into the transfer port but a hole could be drilled anywhere into the crankcase that would expose the port to a crankcase pulse. Then I epoxied a piece of tubing in place so I could attach a hose to the port. I had the top end off the motor so I could prevent the drill shavings from remaining in the engine after the mod. To reverse the mod either epoxy the hole shut or insert a bolt into the other end of the tubing... -Justin
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f13/homemade-reed-kit-3930.html
Posted By For Type Date
» Homemade Reed Kit bikesupplygirl This thread Pingback 10-09-2008 01:35 AM
» Homemade Reed Kit bicyclesupplycat This thread Pingback 10-08-2008 02:57 PM
