I have copied this bit of info over from my Rotten Orange build thread in the photo area, since I figure it might help some folks looking for high quality performance carburetor.
Ok.. In the last 8-10 hours, Ive gone through just about every carb manufacturer, small motorbike manufacturer, and all the aftermarket carbs I could find and finally found/ordered the carb I'll be using for my Rotten Orange build.
The carburetor is a Dellorto 16.16 SHA 16mm:
These SHA carburetors are available in 12, 14, 15, and 16mm outlet sizes, and a number of other sizes in their other product lines. See this site (where I purchased the carb above):
SHA : Dellorto Carburetors, And parts for you.
Other reasons I picked up this carb over other similar small engine carbs:
1) This carb does not use a sliding cylinder and needle to meter air and fuel simultaneously. It's got a small lightweight flat slide that meters the air instead and has separate jets to meter fuel.
2) This carb is jetted, and all manner of sizes of jets are available for proper tuning to my bike's build configuration.
3) Every single part for the carb is available from the www,dellortodirect.com site above and prices are VERY reasonable.. about as cheap as HT carb parts!
4) This carb is a 2 stroke carburetor by design.
5) Dellorto has a comprehensive tuning guide (which I picked up as well with my order)... I'll let you all know how it helps with the tuning.
6) All throttle (and clutch cable feeds) into the carb are replaceable with 40, 50, 70, and 90 degree elbows, all from the above site. This solves problems with top bar clearances in some HT installs (like my last one).
7) This carb uses a 19mm manifold clamp and so is a
DIRECT BOLT IN for 48cc HT motors (ccording to my measurements)
8) This carb is a very compact unit compared to other carb options.
9) Dellorto carbs are used on some of the best of the best 'exotic' superbikes (Aprilia) as well as automotive uses (Porsche). So, they definitely know their stuff.
The parts breakdown of the Dellorto SHA carb:
SHA Carburetor Parts [SHA Parts] - $0.00 : Dellorto Carburetors, And parts for you.
This particular carburetor is available in both cable choke and lever choke for the same price (about $63). I ordered the cable choke, so I can actuate the choke from the handlebars using a spare shimano thumb shifter with the ratchet mechanism removed, thus keeping my hands on the "wheel" so to speak.
I will be fabricating a custom intake manifold for this carb to let me put the carb exactly where I want it, and will allow me to portmatch both ends of the manifold EXACTLY to match the carb and the HT engine.
One interesting thing to note is that the Dellorto 16.16 SHA uses a 19mm manifold clamp. The intake manifold from my 48cc slanthead HT kit measures exactly 18.89mm, so this Dellorto carb is a DIRECT BOLT ON for at least the 48cc HT engines.
I also get a cool sticker for my MAB that not many others are going to have:
Like I said.. I am obsessive compulsive about this stuff..
