| Sponsors
| | | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | HD Happy Time Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. For my winter project i want to totally rebuild my old faithful pk 80cc. It has over 2000kms. I want ...  | |
12-04-2008, 01:12 PM
| | Senior Motorized Bicycle Builder | | Join Date: Oct 2008 Location: Grunthal, Manitoba, Canada
| | HD Happy Time For my winter project i want to totally rebuild my old faithful pk 80cc. It has over 2000kms. I want to replace the crankshaft bearings, wristpin bearings, and piston rings good quality non Chinese stuff. I also want to do some mild porting and compression mods. So, I'm gonna need some help here. Does any one know of any high quality replacements for the rings, crankshaft bearings, wristpin bearings, etc. Suggestions welcome for what else i could do to it to make it more heavy duty/ faster.  |
12-04-2008, 04:50 PM
| | Re: HD Happy Time I disassembled it and was shocked to find out that it had a needle bearing top end. I had always thought it was a bushing. There is some up and down play in the wrist bearing. The rings look not too bad. The cylinder walls look pretty scratched up. The piston looked like there was some overheating .i'm thinking thats from not using a muffler. To those of you who have changed the rings on your engines, at how many miles / kilometers did you do it at?
I put the cylinder back on without the base gasket to find out if the piston would touch the head. I put the head back on to see if i could notice a difference in compression when i cranked it. The piston didnt touch the head, but it might still when it heats up. Once i cranked it, I found out that it has no compression! (yes the spark plug was in) Is this from the lack of nothing sealing it between the crankcase and the cylinder?
Do you guys think that the crankcase bearings that are in there would handle the compression mods? I'm tempted to just rebuild the top end and do porting and mabe compression mods. |
12-04-2008, 05:31 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: HD Happy Time I believe most of the newer HT motors are needle bearing instead of bushed like the older ones. |
12-05-2008, 01:38 AM
|  | Master Motorized Bicycle Builder | | Join Date: Jul 2008 Location: Asia
| | Re: HD Happy Time You need to balance and have the crankshaft centered. Then all other modifications can follow. It is the crank being unbalanced and off-centered that limits the RPM and causes so much vibration on this engine.
__________________ It's more than a hobby, it's my transport. Caution: This hobby is habit forming. |
12-05-2008, 08:44 AM
| | Re: HD Happy Time This perticular engine is pretty good with viberations. I've built 6 happy time motorized bikes and this engine has barley any viberation compared to the rest of them. I think I read somewhere that for the wrist pin bearing you can use a bearing from a o81 stihl chainsaw. |
12-05-2008, 08:47 AM
| | Re: HD Happy Time You may want to try contacting Chris Hill. I believe he has sourced his own bearings and such for his motors. |
12-05-2008, 09:02 AM
| | Re: HD Happy Time good idea. Is he a member of these forums? i dont know his website of hand. |
12-05-2008, 09:04 AM
| | Re: HD Happy Time |
12-05-2008, 09:11 AM
| | Re: HD Happy Time Just PM'd him. Or at least the person whose user name is ChrisHill. |
12-05-2008, 09:15 AM
| | Re: HD Happy Time Quote:
Originally Posted by Technocyclist You need to balance and have the crankshaft centered. Then all other modifications can follow. It is the crank being unbalanced and off-centered that limits the RPM and causes so much vibration on this engine. | I wonder how much a machine shop would charge to balance one of these little cranks. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 08:55 PM. | | |
