Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Has anyone every bored out the cylinder and used oversized rings?
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. Anyone done this to one of our two strokes?...
LinkBack (2) Thread Tools Display Modes
  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 09-23-2009, 02:59 AM
NickDK's Avatar
Default Has anyone every bored out the cylinder and used oversized rings?
Old 09-23-2009, 03:54 AM
NickDK's Avatar
Default Re: Has anyone every bored out the cylinder and used oversized rings?
And yes, I know to do so is foolish.
Old 09-23-2009, 09:30 AM
azbill's Avatar
most 2 stroke engines have a thin nikasil plating on the cylinder wall...not much you can bore there
some of the new grubees have a steel cylinder liner,,,a much better prospect for boring
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 09-23-2009, 10:05 AM
Bikeguy Joe's Avatar
These engines are not bore-able, except as azbill mentioned some of the 50cc engines being sold have a steel liner....but then why not just buy a 70cc if you want a bigger engine?
Old 09-24-2009, 07:11 PM
Steel lined (I have one) or not, there is nothing to bore. Cylinders perform poorly when constructed of aluminum foil.
Old 09-24-2009, 07:29 PM
camlifter's Avatar
if you bored it over and reused the stock piston it would be to loose and probably get a lot of piston knock no mater what size rings you used. the bore must be sized for the piston, not the rings. the rings will be gaped so many .00's per inch of bore.
www.acmemotorbikes.com
Old 09-28-2009, 01:38 AM
If these cylinders are nikasil (which is ****in awesome) then you can bore your cylinder and send it off to be replated. Problem is then finding oversized pistons.
Old 09-28-2009, 08:44 AM
It appears those who are enthusiastic about re-boring never bothered to measure HT cyclinder wall thickness.
  #9 (permalink)
Old 09-28-2009, 09:51 AM
azbill's Avatar
Bill
www.ezmotorbike.com
azgrampa@gmail.com
  #10 (permalink)
Old 09-28-2009, 05:19 PM
Fo'sho'...
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f13/has-anyone-every-bored-out-cylinder-11456.html
Posted By For Type Date
Has anyone every bored out the cylinder and used oversized rings … | Bicycling Leisure Knowledge This thread Pingback 09-23-2009 04:18 PM
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 09-23-2009 08:31 AM
