Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Got my quart of castor Oil!
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. I plan on blending up some of my own oils. Just for fun, experimentation and power in my 67cc street ...
Old 06-14-2008, 08:24 AM
Pablo's Avatar
Default Got my quart of castor Oil!
I plan on blending up some of my own oils. Just for fun, experimentation and power in my 67cc street eater.
If say I mix the castor oil with Amsoil Saber or Dominator, what percent should I use? I mixed some castor with Saber Thursday in clear bottles at 10% and 20% and nothing weird has happened, no separation or anything. I will do the same with Dominator.
I'm out of gasoline and my leetle tank is low, so time to trudge down the hill.
Old 06-14-2008, 09:47 AM
Motorized Bicycle Apprentice
Default Re: Got my quart of castor Oil!
Love the stuff! Hence my username...
You can run the stuff pure, or blend it.
4 oz oil in 1 gallon of gas = a 32:1 mix. I use a "fat" 4 ozs per gallon to achieve approx 30:1 mix.
The recommended mix, however, for our air-cooled two-stroke "Happy Time" (whatever happened to that guy Augi?) bicycle engines is 25:1 but since I believe that commercially-availabe, present-day premix two-stroke oils are of a higher quality than what was around in and when these Chinese engines were first manufactured, I use the slightly leaner mix.
I've ridden my motored at least 1000 miles in the last 6 months and it runs almost flawlessly. Then again, they always run bitchin' right before they blow up, don't they? It's been running crisp for at least three months now!
I typically ride a 20 mile loop and have been using a castor-blended premix racing oil called Castor927. I've become addicted to the scent of the stuff! I buy it from my local Suzuki dealer.
Old 06-14-2008, 10:13 AM
Pablo's Avatar
Maybe I'll make a 50:50 mix of Dominator:castor. I've been running Dominator at about 30:1 as well.....I must admit it's about perfect, so dunno if I'll notice the castor....other than the smell.
Old 06-14-2008, 01:57 PM
Pablo's Avatar
I drained the remaining pint of fuel out of the tank and dumped it in the mower.
I made a 50:50 mix of Dominator:castor, and dumped in 4.25 oz to a perfect gallon of fresh 87 octane. Mixed very well. Started easy. Smoked just the usual amount - but that's just the fuel in bowl. Went for a ride - at first it smelled REALLY funky. Kinda like burned rubber....I'm sure it's just the old oil gooze being consumed and the pipe sealant junk burning off, also I had adjusted my exhaust again. Now smells pleasant and goes fine......the only thing I noticed, it seemed to take a tad longer to warm up to full power, but not a huge problem. Going down the block it hesitated slightly, did a couple jerkies and power just eased on - once warm, full usual power. I'll need to explore this more.
Did some 1st gear grunt laps in the back yard....seems to have even more low end, if that's even possible. Just think when I lower the gear down....from a 10 to a 9 or 8!
Last edited by Pablo : 06-14-2008 at 02:15 PM. Reason: grammar is not even English
Old 06-14-2008, 07:51 PM
Banned
Pablo,
If you are going to do a 50:50 ratio, I highly recommend 3 oz total oil per gallon or you risk a lot of varnish build up on the engine.
Castor's almost magical properties are complement synthetic oil very well and in only small doses. More is not necessarily better. 1 oz castor mixed with 3 oz of Amsoil per gallon would be PERFECT and make less of a mess on the plug and exhaust tip.
The use of roller bearings really negates the need for a rich oil mixture and I'll even step out on a limp and say that 50:1 ratio with AMSOIL would be ok provided there is no risk of overheating the enigne. Castor really shines in temperatures that would cook any other conventional and nonconventional oil because it forms a dry film lubricant when it "cooks off".
I love the smell of burning the bean its something I picked up from model airplane flying....
Thanks for the posting and let us know how it goes. BTW, castor is compatible with almost all oils. It has compatibility issues in fuels that contain a high level of nitromethane.
BTW, I wish AMSOIL made a castor blended oil like other brands.
Old 06-15-2008, 01:10 AM
Pablo's Avatar
OK I'll be watching it......I figure one tank shouldn't kill me!! (famous last words)
Old 06-15-2008, 11:10 AM
Pablo's Avatar
Yeah it's an oily mix - I accidentally left my fuel valve on...and the carb dripped a bit on the smooth concrete.....the fuel evaporated....the mix residue was very nice and oily, not sticky.
I'll pop the head off in 50 miles or so.
