| | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | fancy nonstock carburators Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. what is the advantage of getting one of the "performance" carbs to replace the stock carb? i noticed ...  | |
09-05-2009, 11:05 PM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: Toronto, Ontario
| | fancy nonstock carburators what is the advantage of getting one of the "performance" carbs to replace the stock carb? i noticed that a lot of people here have them, maybe i should think about getting one as well? |
09-05-2009, 11:46 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: tucson
| | Re: fancy nonstock carburators because they flow more air. with a bone stock motor under full throttle you will reach a point where the motor will stop accelerating, and you will hear a completely different exhaust note. that is where you ran out of carburetor. a bigger/more efficient carb will keep pulling. you won't lose any fuel efficiency unless you drive it differently. for a stock motor i highly reccomend a dellorto 14/14 SHA if you plan on joining the quest for speed, get the 16/16 SHA. you can use the stock manifold and throttle cable for both, but you will have to try a few different jets. don't misunderstand though, the 16/16 will not make your bike any faster than the 14/14 unless you need the airflow, (portwork). i can give you the jet size for the 16/16 at 2000' altitude with no filter if you like |
09-06-2009, 11:39 PM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: Houston Texas
| | Re: fancy nonstock carburators Any chance you have the port work for 16-16 at 100' above sea level with a filter?
New to this! Suggestions on part sources?
I live in Houston Texas
Thanks! |
09-06-2009, 11:54 PM
| | Re: fancy nonstock carburators port size and port timing depend (in laymans terms) where in the rpm range you want to make power. when you port a motor, you are increasing the amount of air that the motor will need due to the increased rpm range. the only effect that port work will have on a motor, (other than a decrease in life span) will be the requirement of a larger carburetor |
09-07-2009, 12:30 AM
| | Re: fancy nonstock carburators Quote:
Originally Posted by foureasy because they flow more air. with a bone stock motor under full throttle you will reach a point where the motor will stop accelerating, and you will hear a completely different exhaust note. that is where you ran out of carburetor. a bigger/more efficient carb will keep pulling. you won't lose any fuel efficiency unless you drive it differently. for a stock motor i highly reccomend a dellorto 14/14 SHA if you plan on joining the quest for speed, get the 16/16 SHA. you can use the stock manifold and throttle cable for both, but you will have to try a few different jets. don't misunderstand though, the 16/16 will not make your bike any faster than the 14/14 unless you need the airflow, (portwork). i can give you the jet size for the 16/16 at 2000' altitude with no filter if you like | what does the "14/14 sha" and the "16/16 sha" refer to? whats the best place to get these? |
09-07-2009, 01:27 AM
| | Re: fancy nonstock carburators |
09-07-2009, 05:18 AM
| | Motorized Bicycle Elite Member | | Join Date: Nov 2008 Location: Stockholm, Sweden
| | Re: fancy nonstock carburators How about the SHA 15 15? Does it fit, is it suitable?
(I saw it in a store nearby the other day...)
"Burn after reading" |
09-07-2009, 10:35 AM
| | Re: fancy nonstock carburators yes, all the sha's will fit. but you will have to mes with the jetting to get it perfect. it will be worth the extra effort. |
09-07-2009, 03:11 PM
| | Re: fancy nonstock carburators how does the jet and needle sizing work? how does one find out what the dimensions are when all they specify is "size w6" or "#106"? |
09-08-2009, 12:26 AM
| | Re: fancy nonstock carburators there is no needle on the SHA. just an emulsion tube. what dimensions? you will need some tiny drill bits ( .020-.040") and some solder. it's really not that big of a deal | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 12:57 AM. | | | Sponsors
