| | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | Expansion Chamber and copper pipe header Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. I hope the photo comes up for everyone to see. Nearly ready to install!...  | |
07-05-2008, 12:59 AM
| | Senior Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Australia
| | Expansion Chamber and copper pipe header I hope the photo comes up for everyone to see. Nearly ready to install! |
07-05-2008, 06:44 AM
| | Re: Expansion Chamber and copper pipe header Give's me ideas!
07-05-2008, 08:13 AM
| | Re: Expansion Chamber and copper pipe header Pretty proud of it. I used a pocket bike 'fatboy' expansion chamber which dont seem to be around anymore. Scored it for $35! Because I lack metal shop tools and labour is so expensive in Australia I opted for plumbers copper pipe which has all sorts of ready made bends and pipe diameter reducers. To put it together all I have used is: A hack saw, a tube of 'Quick Steel' high temp epoxy resin putty (great stuff!) a tube of high temp silicone and a hose clamp.
I am going to hack off the end of my stock muffler and join it on, bit of a risk cos I don't want to have to rejoin it back on if something goes wrong...
95% sure it is all good.
Posting pictures of it insalled soon |
07-05-2008, 09:23 AM
| | Re: Expansion Chamber and copper pipe header Yeah more pics will be nice. I love this stuff.
One comment - you didn't solder the copper fittings....? I'm interested on how it holds up. Mine sees huge abuse....I only have a short amount of copper...and it looks like heck now. The spring keeps mine together - I put some goo in to seal it up but it doesn't last. |
07-05-2008, 12:26 PM
| | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: Expansion Chamber and copper pipe header Yea I did JB Weld and it doesnt hold up either, it keeps everything together but leaks more and more every ride. Today I bought a couple of sticks of flux coated brazing rod, 1620 degrees working temp, but Im not sure the Mapp gas torch I have will be hot enough..... |
07-05-2008, 05:10 PM
| | Re: Expansion Chamber and copper pipe header Mapp gas might get it hot enough but it might be border line on being hot enough. One word of caution if you are going to use copper in the exhaust I don't recommend you use alcohol fuel or gas with alcohol.
When copper gets hot enough it will react with alcohol and make formaldehyde with is a carcinogen and really smells bad too boot. I can't seem to get the spell check working today so I hope I didn't butcher the spelling too badly.
Norman
07-05-2008, 05:55 PM
| | Re: Expansion Chamber and copper pipe header I think you spelled them both right...
07-05-2008, 06:26 PM
| | Re: Expansion Chamber and copper pipe header Thanks for the info Norman, gonna try it tomorrow. I just run regular pump gas..... |
07-06-2008, 08:30 AM
| | Re: Expansion Chamber and copper pipe header What I have done is use copper piping which fits snugly into the bends (which it is designed to do). I have high temp siliconed on the inside of these sleeve joints and then applied a ring of the Quick steel putty around the outside. The joint is rock-solid and secure I am not worried about it leaking the question is: Will it take the temperature?
The quick steel is amazing stuff, highly recommended it sticks like glue to metal and sets rock hard. I tested it by sticking a gob on the outside of my stock muffler. It is still there two months later! I also rammed a small bit in between the cooling fins of my cylinder right up against the combustion chamber, it is still there as well and has not become brittle or discoloured at all.
I'll take some close up pics soon. |
07-06-2008, 10:18 AM
| | Re: Expansion Chamber and copper pipe header OK - what exactly is this putty called? Who is the manufacturer? | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 03:09 AM. | | | Sponsors
