| Sponsors
| | | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | Expansion Chamber Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. Could one of you guys tell me the inside diameter ot these tuned pipes.I need to know how big ...  | |
06-18-2008, 09:57 AM
|  | Motorized Bicycle Builder | | Join Date: May 2008 Location: Decatur Illinois
| | Re: Expansion Chamber Could one of you guys tell me the inside diameter ot these tuned pipes.I need to know how big it is wear the header slides in.I have a friend that has a supplier
that sells pipes with extreme bends for industrial uses plus he is an excelent welder.
06-18-2008, 10:04 AM
so i can build my header. |
06-18-2008, 10:11 AM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: Expansion Chamber The inside diameter of mine was 3/4". I used 3/4" copper and couplings to mate it to the header. |
06-18-2008, 11:35 AM
| | Re: Expansion Chamber 3/4" emt conduit works pretty good to. Plus it bends fairly easily...................
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
06-18-2008, 12:26 PM
| | Re: Expansion Chamber Quote:
Originally Posted by Ghost0 Well just to clarify, the use of the 3/4 copper fitting that fits over the pipe means that the outside diameter of the pipe is 3/4. So the inside diameter of the pipe is less. Just remember steel and copper tube have their own set of standards and ways of measuring. I am pretty certain that if you find steel tubing that has a 3/4 outside diameter then that is the one you want. The wall thickness of the pipe is around 1/16 of an inch. Hope this helps. | On my installation that is NOT correct. I used 3/4" plumbing copper. Plumbing copper is measured inside diameter. The outside diameter of the copper is 7/8" as is the outside diameter of the chamber, so the INSIDE diameter of the copper COUPLING is 7/8". The copper coupling was a very good fit on the chamber, but a bit loose on the header (original muffler header).
06-18-2008, 12:56 PM
Originally Posted by misteright1_99 On my installation that is NOT correct. I used 3/4" plumbing copper. Plumbing copper is measured inside diameter. The outside diameter of the copper is 7/8" as is the outside diameter of the chamber, so the inside diameter of the copper COUPLING is 7/8". The copper was a very good fit on the chamber, but a bit loose on the header (original muffler header). | Actually I agree - plumbing copper is ID. My copper coupling was a bit loose on the little header, so I tried to expand it a bit (probably didn't make it much larger), then I roughed both piece up, but didn't remove any material - then I used some $2.99 exhaust system sealer gooze (I'll find the brand and such when I get home) to slip them together nice and snug. Seems to be holding well. |
06-18-2008, 10:22 PM
| | Re: Expansion Chamber mr1-99 - It does look like your pipes are slightly different diameter than others.
Anyhow the goo I mentioned is Permatex #80333 tailpipe putty: PERMATEX 80333 MUFFLER & TAILPIPE PUTTY |
06-18-2008, 11:01 PM
| | Re: Expansion Chamber Cool Thanks Paul, I have JB Weld on it now, it has held for about 50 miles. If it fails I am going to weld it... It cant fail and fall off as I have a support under the pipe as well as a hanger on the chamber. I will just keep and eye on the header to pipe seal.... |
06-19-2008, 01:32 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Bellingham, WA
| | Re: Expansion Chamber Sorry for the misleading, and now deleted, incorrect information. I was going from memory and well, apparently my memory isn't very good. |
06-21-2008, 12:04 PM
| | Re: Expansion Chamber Well I finally got the drill bit I needed and drilled the jet out 1 size to .028 #70. I took it out about 10 miles this morning and it made such a difference. I got rid of the top end sputter, and picked up 1 mph. I still have a midrange sputter, that I believe is the taper of the needle, but its not where I usually cruise so I am not going to try to retaper the needle. When it cools down I still have to pull the plug and look at it, but I am confident that I am there. The pipe is quite a bit louder than stock, and I have put some steel wool inside the baffle in the silencer to to try to force more exhaust around it thru the fiberglass and back into the baffle and out the stinger, rather than having a strait path out, and made quite a difference....
Got it all painted with high temp paint and am ready for summer.....
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:17 PM. | | |
