| | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | different way to mount a tuned pipe Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. One of the fastest, and winning-est GP bikes in the 60's and 70's, I think from Germany ...  | |
02-01-2009, 04:11 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jan 2008 Location: Long Beach Ca
| | Re: different way to mount a tuned pipe One of the fastest, and winning-est GP bikes in the 60's and 70's, I think from Germany used that format. It had a double loop frame so the pipe was closer to the cylinder and ran over the rear tire. Fun to see thinking outside the box. PS: Looks cool too. Have fun, Dave |
05-15-2009, 05:02 AM
| | Motorized Bicycle Newbie | | Join Date: Mar 2009 Location: new zealand
| | Re: different way to mount a tuned pipe hi there norman have you gone back and matched the transfer ports yet. Hows the power does it go better with the carb in front |
05-15-2009, 08:22 AM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: PENSACOLA, FL
| | Re: different way to mount a tuned pipe Norman, Thats Cool. I Remember Seeing That Last Yr, But Forgot About It. I Have Acquired A Identical Exhaust, Even Has The Spring Loaded Flange. How Did It All Work Out. Are you still running it that way, did you do the cyl mods? Ron
PUMP YOUR BRAKES
NEVER BEAT ON IT, GET A BIGGER HAMMER
05-15-2009, 12:17 PM
| | Re: different way to mount a tuned pipe I sold that exhaust/intake/velocity stack/ air cleaner system, I've since returned the engine to front exhaust. It worked very well and I had no over heating problems etc. Yes you can match up the ports it take a little work. Thanks guys glad you liked it.
Norman |
05-21-2009, 10:49 PM
| | Motorized Bicycle Senior Member | | Join Date: Feb 2009 Location: Billings, Montana
| | Re: different way to mount a tuned pipe Where can I buy an expansion chamber/kit? Sickbikes is out of stock! This is a must have item for build number 3. Just got a Giant "Stiletto" chopper and stock exhaust will not look good or even fit very well. I have a PK80 motor for this bike.
05-22-2009, 07:02 PM
| | Re: different way to mount a tuned pipe look on ebay pocket bike parts best I know or google pocket bike shops etc. |
06-12-2009, 02:14 PM
| | Motorized Bicycle Elite Member | | Join Date: Aug 2008
| | Re: different way to mount a tuned pipe wow great thread!!!!
so to make this possible i would just need to invert the head of the motor? thats it, then manufacture an intake and accomodate the pipe?! |
06-12-2009, 02:34 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: "the bog" NH
| | Re: different way to mount a tuned pipe nice norm!! i was just wondering if you can turn the head backwards
DAX 80f
Slanthead
NGK B7HS
SBP performance wire
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!! |
06-12-2009, 06:18 PM
| | Re: different way to mount a tuned pipe you can turn the head backwards it(the engine) won't know the difference. |
11-04-2009, 09:31 AM
|  | Motorized Bicycle Elite Member | | Join Date: Apr 2009 Location: Anderson, IN.
| | Re: different way to mount a tuned pipe Nice job Norm,
But I was woundering. You said you had to match up the ports after you reversed, Would it have been easy'er to reverse the piston aswell ?
Im doing the mod on my OCC, just need to know what Im getting in to.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:38 PM. | | | Sponsors
