dellorto phbg questions SOLVED NOW Hi all just wondering if anyone out there is running this carb as I am looking into fitting one on my mb. What i am unable to find out after searching the net is: the overall length of the carb, measurement from centerline to top of carb and measurement from centerline to bottom of carb. Also what size in mm is suggested? My ports are cleaned and matched,piston skirt is notched out, compression is around 160psi and I am running a sbp pipe. I have taperbored the stock carb but i want to take this project further.
TIA.
