| Sponsors
| | | | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | Carb relocation, longer intake runner Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. I'm about to try to move my carb to, say, the rear panier rack. (it should be below the ...  |
06-08-2008, 09:33 PM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Santa Cruiz, CA
| | Carb relocation, longer intake runner I'm about to try to move my carb to, say, the rear panier rack. (it should be below the fuel petcock i hope) Half the reason to move it is to have room to experiment with intake mufflers. The other half of the reason is to increase the runner length from carb to motor (maybe 8 inches longer). This should boost power in the lower RPMs.
My "problem" is that I live in hill country. Lots of rolly-polly up and downs, and there is never a time that I'm flat out on the flats. Either the motor is over-revving or bogging down. So if the powerband could be broadened a bit so that the other half of the time it isn't bogging...sweet! The other half of the time is gravity assist, and the 44t, "80cc" is into it's sweet spot at 30mph.
I remember one post with a (ridulously long) runner length of three feet with undesirable characteristics. But going from 4 to 12 inches? hmmmm, should work, right? |
06-09-2008, 01:40 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jan 2008 Location: Arizona Bullhead
| | Re: Carb relocation, longer intake runner I would try the other end of the engine and go for a pipe
Either a Moussecan style or a pipe 47cc Pocket bike Performance Pipe.
Mousse can style. Use a 1.5 to 2 inch pipe or a fire extinguisher Mousse Can Muffler
I use the mousse can style from spad to the bone. Start Here
The front of your stock muffler and a new back end. |
06-09-2008, 09:10 PM
| | Re: Carb relocation, longer intake runner Allow me to say I'm not looking for some "backdoor" power boost that no one has come up with yet.
My frame mount engine is so cramped...air filter housing hits frame and can barely be removed, and spark plug wire is nearly against frame as well. So I'd really like to get the carb out in the open. (to experiment with intake muffler, as it's louder than the exhaust). Figured the existing intake is 3/4" O.D. so should be easy enough to route some hose to another section of pipe with a mounting bracket soldered on, and clamp the carb to it.
My main question is if somebody HAS tried it, did they notice any improvement in the power band, as in larger engines, increases length improves performance at a lower RPM) or did performance decrease?. Again, Only about an 8 to 10 inch increase to intake length. |
06-09-2008, 09:22 PM
| | Re: Carb relocation, longer intake runner Quote:
Originally Posted by spad4me I would try the other end of the engine and go for a pipe
The front of your stock muffler and a new back end. | YEAH, THANKS!!! I've been searching forever to get something like this site for mousse can mufflers I saw so long ago!!!
The SPAD RC airplane reminds me of back in the day, early high school, 1990, using 2-inch gutter drain pipe and bamboo, fishing pole, arrowshaft, aluminum c-channel, and what-not to make pod-and-boom airplanes. If we had a crashed plane with decent wing, whip out a new fuse and fly again tomorrow. Used to cut new foam wing cores with hot wire cutter. Probably about 80 kits and scratch-builts over a 6 year span....and only a single fly-able plane stashed in the attic somewhere.
Thanks for the memory-shake! |
06-10-2008, 06:11 PM
| | Motorized Bicycle Apprentice | | Join Date: Apr 2008
| | Re: Carb relocation, longer intake runner I had to relocate the carb on my bike for clearance, My spark plug boot barely touches the brake lines and has rubbed a bit of plastic off the brake line. I am using the CJ7Y plug BTW.
Check out how I did it... My MB PhotoStream It's not the prettiest, or the best. I'm thinking of ordering two intake and chopping them up and getting them welded together to it points out to the side like it does on my bike. The problem I have is the vibrations are amplified by the vinyl hose. |
06-10-2008, 07:45 PM
| | Re: Carb relocation, longer intake runner |
06-10-2008, 09:20 PM
| | Re: Carb relocation, longer intake runner Hey Norman, nice bike, wish I had one like that.................
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
06-10-2008, 09:59 PM
|  | Manufacturer/Dealer | | Join Date: Dec 2007 Location: Charlottesville, VA
| | Re: Carb relocation, longer intake runner HI,
I did the super long intake....gave excellent idle torque and very slow speed torque BUT nothing but bog much faster than idle speed....I say go for the shorter length....it may just be what we are looking for!....I have been soooo busy with work or I would have done it by now...
Andrew |
07-07-2008, 04:11 PM
|  | Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Seattle,W
| | Re: Carb relocation, longer intake runner well i had an issues with my bike when i mounted the motor to it this weekend . i bought a brand new schwinn creek. its had a nice back bone the flowed nice with the gas tank on it.. but the down side was the crab would not fit at all. so after about 6 hrs of trying to make and think of making a new intake my 9yr old sone was playing with a 3/4 heater hose and then it came to me...so i put the heater hose on the intake and added a 3/4 in peice of pipe so the carb would bolt to it and BOOM it look,fit and RUNS GREAT...
ill upload a pic of the bike and crab when i get home... | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:28 AM. | | |
