| | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | Bigger Gas Tanks Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. Does anyone know of any good tanks that are maybe a gallon or more that can be easily installed
without ...  | |
05-29-2009, 11:23 PM
| | Motorized Bicycle Member | | Join Date: May 2009 Location: Santa Cruz, CA
| | Bigger Gas Tanks Does anyone know of any good tanks that are maybe a gallon or more that can be easily installed
without any modifications, that just screw on like the stock ones? Maybe that wrap aound the frame? And also, can you put wider tires on your cruiser for a smoother, more stable ride?
Cheers |
05-29-2009, 11:37 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: Upstate,NY
| | Re: Bigger Gas Tanks first id like to get a smaller tank with a petcock,something that dont look like a football that the stock tank looks like.second my scwhinn delmar cruiser already has wide 2.125" tires front and back any wider and there wont be room for a sprocket or anything and any wider and there would be clearance issues with the chain. |
06-01-2009, 02:08 PM
| | Motorized Bicycle Newbie | | Join Date: May 2009 Location: beaumont ca 92223
| | Re: Bigger Gas Tanks ive got fat nobs on my back and flat city crusers on the front i have no prolems with it at all but you have to keep tires hard back tire is a 2.275 and the front is a 1,175 |
06-01-2009, 02:13 PM
| | Re: Bigger Gas Tanks where can i get a 1 gal. gas tank got a 80cc im mean theres notting wrong with it i just want to go the 150m to the gal. to the beach and back ie so cal thanks |
06-01-2009, 03:13 PM
| | Re: Bigger Gas Tanks one of the engine kit sites sell 1 gal tanks but im not sure which one.if i find one i will post it. |
06-01-2009, 05:56 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2009 Location: usa
| | Re: Bigger Gas Tanks stock tanks are 3/4 gallon... you could create a 1/4 gallon reserve with a 2nd smaller tank zip tied to the frame. could use a soda bottle and zip tie it to the frame.. hose running in, and hose running out the bottom to the carb.. seal the bottle up with silicone so it don't leak.. silicone good gas line in it and not the cheap plastic stuff from the hardware.. only trouble is, you would have to open the petcock to get it filled first, then close it and refill the tank. |
06-01-2009, 08:46 PM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2008 Location: Tampa Bay, FL
| | Re: Bigger Gas Tanks Stock tanks are 2 liters, so 1/2 a gallon...
Some will hold .6 gallons. I've never seen one that will hold 3/4 gallon.
There is a 4 liter tank available on ebay. (1 gallon)
'BrettMavriK |
06-02-2009, 06:22 PM
| | Re: Bigger Gas Tanks Quote:
'BrettMavriK | the tank that came with mine is listed as 3/4 gallon.. who knows if it really is.. I didn't measure |
06-03-2009, 10:21 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jan 2009 Location: Phoenix, AZ
| | Re: Bigger Gas Tanks BoyGoFast on ebay has some bigger tanks. There are a couple other 1 gallon tanks out there as well. I'm waiting for "ghent" and his tanks as an option.
Map your motorized bikes location on a Frappr Map show us where you are and post a pic of your bike. If trailer parks didn't exist would tornadoes exist? |
12-20-2009, 10:28 AM
|  | Motorized Bicycle Member | | Join Date: Sep 2009 Location: Norfolk, VA
| | Re: Bigger Gas Tanks We haven't finished our Ghent design yet. But, we have these Sachs Vintage Tanks available now:
More info here  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
