| | Beefed up ignition?? Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. Originally Posted by fairracing31
Isn't the crf & Xr 12 volt? I gave one of my mag's from ...  | |
04-15-2008, 08:11 PM
|  | Custom Builder / Dealer | | Join Date: Mar 2008 Location: Venice, CA.
| | Re: Beefed up ignition?? Quote:
Originally Posted by fairracing31 Isn't the crf & Xr 12 volt? I gave one of my mag's from one of my new kit's to my MSD dealer. He's going to see what he can do with it but I have not spoken to him yet. I'll see if I can get a hold of him today and see if he came up with anything. |
I'm guessing that since it's a REALLY small engine with no battery, that it's a 6v...
I looked, but haven't found anything on line about it.
04-16-2008, 02:04 PM
| | Re: Beefed up ignition?? He has not had the chance to look at it yet. I'll give him a few more day's.
I was told about NCY¤d¸*³¡«~¾÷¨®¹s¥ó»s³y§åµo
I took a quick look but have not had the time to really see what they have. |
04-17-2008, 08:47 PM
| | Re: Beefed up ignition?? Update...I wired up the new XR50 CDI & coil with the new wiring harness to my engine... NOTHING, NO SPARK!!!
I'm sure that the new CDI uses a separate magnetic trigger to fire it, & a stator to power it up.
Our current mag-coils do both off of one wire!
I found a small mag-trigger & stator for a XR50 on Ebay, but it's still too big to fit in the side of our engines... (modify?)
I'll keep looking!  |
04-19-2008, 11:04 AM
| | Re: Beefed up ignition?? Heres a pic of the XR50 part that I found on ebay... The back plate is 4.5 inches across.
I was thinking that maybe the back plate could be cut down to fit in our engines?
I really think this part will work if I can make it fit into the engine and get the timing set...
Any thoughts??
04-20-2008, 07:43 PM
| | Re: Beefed up ignition?? If you could get it to fit, and use the XRCDI, we are going to 12 volt right? Everybody I have talked to say's the XR is 12 volt.
Got my mag back.......John (MSD dealer) said nothing can be done to improve it. He used smaller wire on the coil winding and bigger wire. He said the smaller wire does improve the juice a very small amount. But not enough to improve performance.
If it will fit VB, yeah, all we have to do is figure the timing. If we can get it to fire on every stroke, and not every other stroke, we should be okay. |
04-20-2008, 07:58 PM
Originally Posted by fairracing31 If you could get it to fit, and use the XRCDI, we are going to 12 volt right? Everybody I have talked to say's the XR is 12 volt.
If it will fit VB, yeah, all we have to do is figure the timing. If we can get it to fire on every stroke, and not every other stroke, we should be okay. | I think the way they work is... that they DO fire on every stroke, just every other spark is a dead spark on the exaust stroke!  |
04-20-2008, 08:08 PM
Originally Posted by VENICE BOY I think the way they work is... that they DO fire on every stroke, just every other spark is a dead spark on the exaust stroke!  | Your right, I dont know what I was thinking. I'm going to Phoenix Wed. for work. They have a huge motorcycle junk yard, I'm going to go dig around and see what I can find. Hopefully I can find a XR50, it would be alot easier to see what you are working with. I also hope to find some 50cc scooters and see if anything will work.
By the way, I just used the mag my friend looked at. It dont work now.... I dont know what he did and dont see why there is no juice. Maybe changing the coil winding is not a good ideal  |
04-20-2008, 08:30 PM
| | Re: Beefed up ignition?? |
04-20-2008, 09:19 PM
| | Re: Beefed up ignition?? I think the set up I found on ebay is a better bet... The original equipment on a xr50 is a stator & a big "bell" magnet, that I'm pretty sure wouldn't fit in the engine...
The ebay one is much smaller, & the back plate can be cut. (I hope)
I'm thinking about just buying it and praying I can make it all work.  |
04-20-2008, 09:44 PM
| | Re: Beefed up ignition?? Anybody doing your timing will need a degree wheel.
I found this place that gives you five diferent sizes of wheels. Just download, print, and cut. Saves 20 buck's. I made mine out of sheetmetal. Motorcycle Degree Wheel
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Tester for ignition | Norman | Bicycle Engine Kits | 4 | 07-18-2008 01:20 PM | All times are GMT -5. The time now is 02:03 AM. |
