Norman, I download to my jump drives at the public library when using their computers & high speed LAN. Then install from it when I get home. I'll do that with these soon as I get to the Library.
But the IWT software took some playing around with for me as I don't have an in frame motor (torn down much less) to take measurements from. So, I just dreamed things up. My Tanaka isn't a likely candidate for an expansion chamber unless the 33cc chamber can be less than
36 inches long and mount to the right fork somehow.
Another software is here, and takes about 10 seconds to download on dial up:
The Expansion Chamber Design Software
For $40 dollars Build and Click.com has their 2 Stroke Wizard Expansion Chamber Design Software. 30cc and up, multi fuel, Win 98 and up. (If any of a group would purchase it together to use) I didn't see a trial but there may be one.
Here is a Free Java Applet Chamber Design ap that requires Java 1.4 (says it won't run on the old windows VM) I've had it up and it has loads of things going for it. Takes a few minutes to load but looks interesting. It's reviewer says this.
JavaPipe: Tuned Pipe Designer
It also allows you to export a .dxf file for the blanks to make the cones and stright sections from. The file can be used by many CAD softwares.
You can slide each value and see what part of the pipe they change. You can also type in specific values or values that are beyond the range of the slide.
SteelSnakes is a Free expansion tube design software. Look for it half way down the page here: (lottsa neat stuff for the math nuts here)
The Archive
Harbor Freight has this 12" x 20 gage slip roller for $150. If none of the cones are over 12" long.
Harbor Freight Tools - Quality Tools at the Lowest Prices
Their 90 amp flux wire feed/non gas welder is $129 but I've seen it on sale in the store for $99.
But somewhere around $300 bucks and some free software could put a person who wanted to, making custom chambers that would sell for $75 bucks easily enough. A few chambers would net a breakeven fairly soon. If the motorbicycling trend continues to grow given gas prices....well those here doing this would be aboard as vendors already.
