Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
40mph speed secrets revealed
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. i will periodically add pictures and the reasons why, for a few of the things that i have done in ...
LinkBack (5) Thread Tools Display Modes
  5 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 09-12-2009, 01:17 AM
foureasy's Avatar
Default 40mph speed secrets revealed
i will periodically add pictures and the reasons why, for a few of the things that i have done in the quest for speed.
i did this to my combustion chamber to make it a more efficient "squish" type chamber. it helps to promote a more even flame travel and less risk of detonation. not to mention the added benefits of increased compression. the ideal size of the squish band is 1/2 of the bore area, which i have come pretty close to.
weld it up
face it and grind it out
i got five on it
Old 09-12-2009, 02:40 AM
Rockenstein's Avatar
Thumbs up Re: 40mph speed secrets revealed
Nice job with the fill welding trick
I wondered about attempting that on a spare head I have but the welding guy I talked to said it would likely warp real bad...looks like yours survived so I may take it back and tell him to go for it.
To others that try foureasy's mod a nice finishing trick to use once you've roughed out the combustion chamber shape by hand or in a lathe is as follows...
Grab a few lengths of 1 1/2" - 2" hardwood dowel and shape the ends to the desired combustion chamber shape with a belt or disc sander. Get some various grits of sand paper and glue them smoothly to the shaped dowel ends with contact cement. Starting with a 180 or so grit work the dowels in the combustion chamber like your starting a fire the hard way...the end result should look real nice and be smooth enough to avoid any possible detonation issues.
PS: foureasy is this your finished and running head? Wondering if you touched up the pitted areas on the squish band or not? I'm concerned glowing deposits could get in lodged in them and cause some unexpected detonation...
I refuse to be taken apart...
Old 09-12-2009, 09:06 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: 40mph speed secrets revealed
Let us know how it runs!!
Old 09-12-2009, 10:03 PM
foureasy's Avatar
it runs great, this thread is based on the things that i have already done to do 40mph at 8000 rpms.
rock, those pitted areas are as good as i have the patience for. they are right where the filler rod meets the base metal, (whatever that is). i have seen no evidence of detonation so far. the only issue i've had with this motor is the connecting rod bearing on the small end. i picked up some nice american made bearings to replace the stocker.
sometime in the near future i'm gonna mill up a billet head that is hugely oversize, to combat the heat issue here in tucson.
Old 09-13-2009, 12:34 AM
foureasy's Avatar
sometime soon, i'll port a used cylinder i have laying around and show some of the layout tricks
here is a sneak peek of my exhaust port
here is an intake port
Old 09-18-2009, 12:28 AM
foureasy's Avatar
here is a working cylinder head as a blank canvas. i'm picturing swiss cheese.
Old 09-18-2009, 06:45 PM
cobrapowered1's Avatar
Far out head foureasy, is that a dual carb setup ? Nice.
Old 09-19-2009, 02:03 PM
foureasy's Avatar
it is a dual carb setup. here is the aforementioned swiss cheese. sorry about the cell phone pics.
  #9 (permalink)
Old 09-19-2009, 02:45 PM
azbill's Avatar
that is a lot of drilling !!!
does it help you enough to be worth the expense/effort ???
enquiring minds want to know
Bill
www.ezmotorbike.com
azgrampa@gmail.com
  #10 (permalink)
Old 09-20-2009, 02:01 AM
foureasy's Avatar
i was having huge headgasket issues. every cold start resulted in a whistling head gasket until operating temp was reached. i think i need to go back and drill the holes a little bigger, it still seems to get too hot. i still want to get a billet chunk twice as thick and put some radial fins in it like the old two strokes
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f13/40mph-speed-secrets-revealed-11141.html
Posted By For Type Date
Best tuned pipe for This thread Refback 10-05-2009 01:30 PM
Best tuned pipe for This thread Refback 09-29-2009 04:14 PM
Best tuned pipe for This thread Refback 09-29-2009 12:47 AM
40mph speed secrets revealed - Motorized Bicycle Engine Kit Forum | Bicycling Leisure Knowledge This thread Pingback 09-13-2009 07:46 PM
40mph speed secrets revealed - Motorized Bicycle Engine Kit Forum ideal This thread Pingback 09-12-2009 10:42 AM
