High Performance Bicycle Engine TipsWe all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
4 stroke airbox Mod
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. I stumbled upon a quick and easy performance boost for the 49cc Honda clone engines. The stock air cleaner inlet ...
I stumbled upon a quick and easy performance boost for the 49cc Honda clone engines. The stock air cleaner inlet is very restrictive, and was causing my engine to bog and hesitate at midrange rpms. I resolved this by simply enlarging the inlet with an exacto knife. I only needed to expand the inlet by about 1/8" across before the engine began to idle more smoothly. Now it runs like a champ. The only downside to this is it made the engine a bit louder, if you consider that a problem.
Now, if only I could figure out a way to hush the gearbox whine...
__________________ Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
Here's my "high tech" Honda GXH50 airbox...of course I was going for "retro", not performance, but I'll take what I can get. Of course I also had to replace the original airbox because it would not fit.
...and in the spirit of retro, that garish red cover color will be going away soon along with all the stickers- body color, same as the filter housing.
Nice...that's a major improvement on the stock airbox. I'm a fan of the retro look as well.
Is your airbox from one of the small russian engines? I removed the red cowling from my engine, and it looks much better...less like a lawn mower
Opening up the intake has really made a difference on my bike. I love riding it now. The gear whine is either quietening down or maybe I'm just getting used to it.
Anyway, I'm becoming a fan of these 4 strokers.
- Albert Einstein
That's awesome..motorbikers sure are resourceful. Do you have any suggestions for improvising a fuel tank?
- Albert Einstein
I don't want to get away from the air box mod issue, but since you asked, I used the standard tank and fabricated a fiberglass cover to mimic a more vintage look.
I made a form out of foam board, glued fleece on (in the future I would use fiberglass cloth because the fleece required a lot of smoothing), brush on resin, sanded, brushed on more resin, sanded, then filled, primed and painted- it sounds easier than it was. The tank is secured with polyurethane adhesive and polurethane foam.
