Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motor Bicycle Safety
Motor Bicycle Safety Share safety tips for motorized bicycles. Some of these bicycle engines will reach great speeds and need respect.
NOTICE: Safest Chains For 66cc/80cc power king motor.
Discussion at Motorized Bicycle Engine Kit Forum in the Motor Bicycle Safety forum. !HOW! Crazy Horse wants to know what is everyones opinion on the safest strongest chain for the zoombicycles powerking black ...
Old 07-13-2009, 01:59 PM
Dealer
Default NOTICE: Safest Chains For 66cc/80cc power king motor.
!HOW! Crazy Horse wants to know what is everyones opinion on the safest strongest chain for the zoombicycles powerking black stealth 66cc/80cc.
This is my first 80cc motor the kit came with a DH-083 (50 XINGQIYOUJILIANTIO JIAQIANGXING) chain.
The kit chain is a chinese size 50 1/2 Inch! I might be mistaken on that.
The BMX chain from F&R is a size........ what? Was supposed to be BMX 415 Chain.
I'm putting this motor on a greenline stretch cruiser for a customer & I know I should have known better the kit chain is to short.
I ordered 3 chains BMX from F&R Cycles and the will not fit.
Any suggestions on chains that are safest that will best fit this motor are appreciated. Thanks.
Should I use a #41 or 415 or what do you mb'ers suggest?
BTW Crazy Horse say Many Thanks To RedB66 for Motor Mount Design They're Super Strong!!!
NOTICE: Must See ( wheel rims thread more info 68 spoke ) Crazy Horse no shoot bow & arrows now suffers from 68 spoke-finger-itis
Peace Crazy Horse.
PS am I just another crazy injun or am I blind whats wrong with these 2 chains can you see what I see?
NOTICE: Safest Chains For 66cc/80cc power king motor.-dscn0754.jpg  NOTICE: Safest Chains For 66cc/80cc power king motor.-dscn0755.jpg  NOTICE: Safest Chains For 66cc/80cc power king motor.-dscn0749.jpg  NOTICE: Safest Chains For 66cc/80cc power king motor.-dscn0753.jpg  NOTICE: Safest Chains For 66cc/80cc power king motor.-dscn0752.jpg
Old 07-13-2009, 03:02 PM
Default The metric 219 chain
The metric 219 chain is a strong, compact design, used in Kart racing in Europe and Aisia. Lots of sprockets and chains are sold relatively inexpensively on Ebay.
Old 07-13-2009, 06:54 PM
dvddtz's Avatar
Default Re: NOTICE: Safest Chains For 66cc/80cc power king motor.
I have always used the stock chains,and so far have had no problems.In fact my first build had over 2500 miles on the original stock chain.But many people do use the #41 chain.I know that didnt help,but that has been my experience so far after 10 total builds.David
Old 07-13-2009, 07:19 PM
Cabinfever1977's Avatar
that bmx chain looks like 1/8" which is for multispeed bikes like mountain bikes and other bikes 10-21 speed or small kid bmx bikes,also could be for a special bmx bike.
1-3 speed bikes like cruiser bikes and adult bmx bikes come with 415 chain which is 3/8" and is also the main size these kits usually come with,a few come with the thinner 1/8" regualr bike chain thou.
i use the 415 and the 415 chain will work fine but you can use the 41 if you want to.
Old 07-13-2009, 07:57 PM
Retmachinist's Avatar
I would definitly use #41 chain. The side plates are smaller than the kit chain, but it is still 1/2" chain and alot stronger according to the tensil strength charts. The #41 chain, master links and off set links are alot easier to find than the original kit chain. TSC and Northern both stock it. Comes in a 10 Ft. length for about $12.
John
Old 07-14-2009, 01:09 AM
Type of chain vrs 750 watts of power ? [Archive] - Bike Forums
EbikeHawaii07-
This is for those who spend the time to make a lighter more efficient system than you can get from any hub motor.First of all on mid drive systems it does not make any sense to gear down a motor to drive bicycle chain to match the pedal cadence to drive through a bike chain and a clunky derailer using a 750 watt motor.With less reduction (about 8 to 1 for a 26" wheel) you would be best off using a 219 or 8mm gocart chain and composite sprockets from 72 to 92 teeth that cost as little as $8. each if you look around.Of course you will need a strong low 2000 rpm torque motor above 1 hp or 750 watts of power to eliminate power robbing multigear reductions that all mid drives on the market offer..Multigeard hubs have a great efficiency because the ratio is low and they spin fairly slow.Not so with 3000 rpm motor reducers.These sprockets and 8mm chain are the most efficient chain/sprocket arrangement you can get for up to 25 HP and 12,000 rpm.
At 750 watts they are much more efficient than bike chain or #25 chain and the 8mm chain won't stretch at all.For 4 years I have only used this arrangemet on my ebikes...You can adjust sprocket ratios rather easily compared to buying another hub motor.
219 Sprockets are 40% lighter than anything on the market today. Made of Kevlar, these sprockets are stronger, quieter, more durable, and feature less sliding resistance (keeping the sprocket cooler, thereby increasing chain life) than either aluminum or steel sprockets. Specifically made for karts using 219 chain and 6-bolt carriers.
Old 07-23-2009, 08:22 PM
Looks like you have the typical junk 415 HD chinese chain. It's crap, look at how the roller bushings aren't even wide enough? It stetches like a piece of hot cheeze, unevenly I might add. It will crunch and snap under pedal power. I replace mine with a quality chain and it was worth it! Cost about 15.00 USD shipped and it was made by KMC. From what I've read, the 4 in the number means 1/2 inch pitch the rest has to do with the width. Made sure you get a 415 HD chain from what I see in your pictures.
Old 07-24-2009, 09:14 AM
I'm running 420 chain from KMC. Nice quality chain! It is a bit wider, but same pitch.
  #9 (permalink)
Old 08-02-2009, 03:04 AM
Junster's Avatar
Maybe this link will add some insite to the chain sizes and strength.
Azusa Engineering, Inc. Online Catalog - Roller Chain, Motorcycles, etc.
Put something FUN between your legs..
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f11/notice-safest-chains-66cc-80cc-power-9578.html
Posted By For Type Date
Info.com - 66cc - www.Info.com This thread Refback 09-10-2009 03:52 AM
