Huffy, sometimes the simplest cure is to buy a 21-speed bike that has better brakes and suspension fork.
A friend is selling a Raleigh Venture 3.0. This bike allows people with short legs to touch ground. If it's a 17" frame with suspension fork, I'll buy it.
I went down to the bike shop I'd bought the bike from and asked about cruiser rear brakes. Owner said the distance from rim to proposed brake attachment is too far.
I might temporarily rig a crossbar closer to the rim and bolt the front center pull brake onto the frame. If it works, that'd be great.
My son wants to ride a bike for exercise. If I buy the Venture, I'll just let him ride this cruiser bike with no engines.
This week should be busy for me. The Staton freewheel sprocket arrived, as well as a Staton output shaft. I'm gonna drill the Staton chain drive box to install the output shaft, which will provide a 5:1 gear reduction to run my 12volt/55watt mini-alternator.
The Mits engine/rear friction drive on "The Dragon Lady" fired up and drove the bike, but the pocket bike engine wouldn't start and the pull start mechanism jammed.
It will be a busy weekend.
