| Sponsors
| Our Forums | | | | Motor Bicycle Safety Share safety tips for motorized bicycles. Some of these bicycle engines will reach great speeds and need respect. | Fuel Tanks and Fire Discussion at Motorized Bicycle Engine Kit Forum in the Motor Bicycle Safety forum. Guys,
This is a strange one but one that needs to be shared here because all of us, except our ...  | |
10-29-2009, 04:28 PM
| | Fuel Tanks and Fire Guys,
This is a strange one but one that needs to be shared here because all of us, except our electric compadres have fuel tanks and gasoline to contend with.
An old firefighter buddy of mine, recently retired, knowing that I have motor bikes, called me and relayed a story he had read about in a firefighter newsletter he subscribes to.
A man was working on his motorcycle and had removed the gas cap. Presumably to keep dirt out and to keep the fumes in, he covered the hole with a strip of cellophane tape and when he was ready to put the cap back on he ripped the tape off and, apparently, there was a static spark that set off the vapors. He was not badly burned but his bike and garage were destroyed by the ensuing fire. The man was not smoking and there were no other ignition sources in the vicinity of the bike so static spark was ruled the culprit. It is not known if the tape or the man's hand generated the spark but with that in mind I plan to be a little more careful whenever I have the fuel tank open for any reason. This is probably one of those 1 in a million cases but still something to be aware of.
Over Youth and Skill |
10-29-2009, 05:18 PM
| | Motorized Bicycle Elite Member | | Join Date: Sep 2009 Location: Texas
| | Re: Fuel Tanks and Fire They make you attatch a ground cable before you pump fuel out of a tanker truck for the very same reason. |
10-29-2009, 07:45 PM
| | Motorized Bicycle Elite Member | | Join Date: Apr 2009 Location: somewhere around you
| | Re: Fuel Tanks and Fire also guys dont have your cell phones in pockets or be using them while fueling this is good story tobe talking about because you will not here about these storiers unless you are in gas bus. or fireman etc. or envirmental work. TO everyone here at this site, your family is counting on you to safe! HAVE A SAFE TRICKER TREAT!! |
10-29-2009, 07:56 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: Mi
| | Re: Fuel Tanks and Fire Quote:
Originally Posted by the willi also guys dont have your cell phones in pockets or be using them while fueling this is good story tobe talking about because you will not here about these storiers unless you are in gas bus. or fireman etc. or envirmental work. TO everyone here at this site, your family is counting on you to safe! HAVE A SAFE TRICKER TREAT!! | Urban legend. snopes.com: Cell Phone Use at Gas Pump |
10-29-2009, 07:59 PM
| | Re: Fuel Tanks and Fire i was thinking (luckily, just thinking) about fire the other day, when i installed a new clutch cable. my favorite method of making sure the end of the cable doesn't fray, is to put some heat shrink tubing on it.
with a lighter.
and it's right underneath the air filter.
the filter has a sponge filled with gas inside of it.
think about that the next time you're torch soldering or heat shrinking that cable end.
(i was also smoking at the time, since i had a lighter in my hand...) |
10-30-2009, 01:52 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: Asia
| | Re: Fuel Tanks and Fire living dangerously? must have good insurance...
__________________ The Noah's Ark was built by amateurs, the Titanic was built by professionals. I build my Motorized Bicycle. Caution: This hobby is habit forming. |
10-30-2009, 02:46 AM
| | Motorized Bicycle Elite Member | | Join Date: Sep 2009 Location: fort collins colorado
| | Re: Fuel Tanks and Fire dont use matches to see how much fuel is left in the tank!!!! |
10-30-2009, 09:28 AM
| | Motorized Bicycle Member | | Join Date: Sep 2009 Location: modesto
| | Re: Fuel Tanks and Fire Great post 2Door, good looking out  Its also a habit of mine to never fuel my bike in the garage, or mix my gas in the garage as well. I always open the garage door go outside with my bike and gas can and do it there. |
10-30-2009, 01:28 PM
| | Re: Fuel Tanks and Fire don't use a vacume to clean up a fuel spill! (Motor's brushes make sparks) |
10-30-2009, 03:44 PM
| | Motorized Bicycle Elite Member | | Join Date: Feb 2009 Location: British Columbia Canada
| | Re: Fuel Tanks and Fire Rode with a bunch of bikers in the early 60s and one guy used to check his gas with a flash light. Worked great until his buddy stuck his head into the tank filler to take a look too.
Should have put the cigarette he had in his chops, out first. It was not pretty.
Steve. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:41 AM. | | |
