| | | Motor Bicycle Safety Share safety tips for motorized bicycles. Some of these bicycle engines will reach great speeds and need respect. | Front Wheel Brake Drum Discussion at Motorized Bicycle Engine Kit Forum in the Motor Bicycle Safety forum. Do I need to change my fork for this wheel drum brake kit from huffy? I am hoping that a ...  | |
09-19-2009, 11:15 PM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2009 Location: Howell, New Jersey
| | Front Wheel Brake Drum Do I need to change my fork for this wheel drum brake kit from huffy? I am hoping that a regular fork will work with it.. 26" FRONT WHEEL WITH DRUM BRAKE HUB: Husky Bicycles
09-20-2009, 12:23 AM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Fountain Hills, Arizona
| | Re: Front Wheel Brake Drum nope...I used a drum on the stock jag forks and, am still using it on my springer
it's simple bolt on !!!  |
09-22-2009, 08:44 PM
| | Re: Front Wheel Brake Drum That's a real good price on that wheel!!
You will probably have to find (or make) a oversize strap to attach the drum arm to the Felt fork leg.
09-22-2009, 11:27 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: Mi
| | Re: Front Wheel Brake Drum Quote:
Originally Posted by VENICE BOY That's a real good price on that wheel!!
You will probably have to find (or make) a oversize strap to attach the drum arm to the Felt fork leg. | Yea I owe azbill a beer for posting that link before. lol
Their shipping is a little steep but it's still cheaper then lacing one up yourself. Think I'm gonna order two to try and save a bit on shipping, one for the cruiser and one for the board track bike I want to build over the winter. |
10-06-2009, 06:25 PM
You will probably have to find (or make) a oversize strap to attach the drum arm to the Felt fork leg. | Yeah Venice,
I am having a problem with the brake arm strap. The one that comes with the kit is very small/ I need at least an inch and a half front brake strap.
Anyone in the forum had a fix for this front brake arm strap problem... |
10-06-2009, 06:47 PM
Originally Posted by azbill nope...I used a drum on the stock jag forks and, am still using it on my springer
it's simple bolt on !!!  | Hello,
What is the fork diameter of your Jag..I think it should be the same with Felt. Mine did not bolt on as the brake arm strap the comes with it is too small.. |
10-07-2009, 01:00 AM
| | Re: Front Wheel Brake Drum I have used the wheel on 3 different bikes and 4 different forks
when it was mounted on the haro mtn bike with fat forks, I used a piece of thick hose to fill the space between fork and arm and hose clamped it
I used a good clamp for high pressure hose, not a cheapie from ace  |
10-07-2009, 01:17 PM
| | Re: Front Wheel Brake Drum Actually a SS hose clamp would probably work pretty well. |
10-07-2009, 03:08 PM
| | Re: Front Wheel Brake Drum Just make a strap from a piece of thin flat steel from the LHS... |
10-10-2009, 07:03 AM
| | Motorized Bicycle Member | | Join Date: Sep 2009 Location: modesto
| | Re: Front Wheel Brake Drum sturmey archer even makes a hub with a generator in it too, outputs 3w or something like that, I am thinking of using one on my MB, the white wire lights I have on it now seem to bog my engine a bit, nice find on the wheel though, from what I've heard those hubs are very durable | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:47 AM. | | | Sponsors
