Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motor Bicycle Safety
Motor Bicycle Safety Share safety tips for motorized bicycles. Some of these bicycle engines will reach great speeds and need respect.
Front Fender Problem on a motorized bicycle
Discussion at Motorized Bicycle Engine Kit Forum in the Motor Bicycle Safety forum. It WAS a beautiful Schiwn Cruiser. My buddy was riding home and he said he was only cruising around 20-...
Old 02-10-2008, 11:25 AM
Easy Rider's Avatar
Default Front Fender Problem on a motorized bicycle
It WAS a beautiful Schiwn Cruiser. My buddy was riding home and he said he was only cruising around 20-25mph and the fender tab that attaches to the forks near the brakes snapped off. Before he relized he was on the ground. I'm glad he wore his helmet that day. I've noticed on my bike that speeds over 32mph my front fender vibrates like a S.O.B. Also I know (just like everything else in the world) some factorys don't build bikes like they use to.
BEFORE
AFTER
Old 02-10-2008, 12:03 PM
deacon's Avatar
Default Re: Front Fender Problem
Greak looking bike.
I have the fenders off the next one I'm going to build. i did it to get a larger wheel and tire on it. I found that once I did that I could get a hand brake for the front wheel as well. The rear one came off to mount an electric motor but that is gone now. I still have the front fender on my Sissy Schwinn but I have been having second thoughts about that as well.
But then I don't know, I might put a chrome cut down rear fender on it once I get the chain situation right. I'm going drill and bolt it so that I can actually get to the bolts to check them.
visit my blog for Riding in the hood,... The home brew bike journal....http://frictiondrivebicycles.blogspot.com/ The deacon's fiction
Old 02-10-2008, 12:09 PM
Bikeguy Joe's Avatar
MODERATOR
Key word is WAS.
Hope the rider faired better than the bike.
I used JB Weld where all fender tabs were on my bikes.- front and rear.
Old 02-10-2008, 12:10 PM
MODERATOR
Dang, I just noticed, he wrecked it so hard he changed the pipe!!
Old 02-10-2008, 12:15 PM
Norman's Avatar
LORD VADER Moderator
I don't run fenders for that reason. I wish I had a good or better answer than that. Fenders do help to keep the nasties off you but if they come loose the results are not good.
I hope you are not hurt. Bike looks to be damaged badly, lot of work to fix. You might be better off to replace and use the damaged bike for parts.
Norman
norms-iron-works.tripod.com
Old 02-10-2008, 11:57 PM
Easy Rider's Avatar
Did you noticed that the front tire locked up so bad that it bent the forks?
Old 02-11-2008, 01:20 AM
Easy Rider's Avatar
Norman
I'm banged up but for a different reason. But my friend snapped his collarbone and broke 3 ribs. I saw him today @ the races and he's pretty banged up.
Old 02-11-2008, 07:00 AM
deacon's Avatar
When I was twenty three I was hospitalized for blacking out for a second behind the wheel of my car and driving it into a sign. The road was slipper from the ice storm so the second was all it took. At that time they couldn't find out the cause but the doctor warned me it might happen again. So I asked, "Should I stop riding my motorcycle?"
"Son I tell you what I tell all my patients," he replied. "If you ride it long enough, it will kill you." Naturally I didn't stop but that bike picture reminds me how dangerous all these bikes are. These seem to be even more fragile than the big bikes. Part of the allure I'm sure.
  #9 (permalink)
Old 02-11-2008, 07:10 AM
MODERATOR
Definitely "more fragile" but they cause less damage to whatever they hit.
I had over 500 miles on both the bikes I built before I sold them and ALMOST no fender problems. I just removed them and went over the places where the fender brace connected to the fenders. I "reset" the rivets and coated the whole brace/fender union with JB Weld.
The one problem I did have was one of the rear fenders cracked where I cut it for clearance for the drive chain.
That was my fault.
  #10 (permalink)
Old 02-12-2008, 03:40 PM
nogoodnic's Avatar
I use hardware store L brackets on all of my bikes with fenders. All you have to do is drill out the original rivets, lose the cheap peice of tin the comes from the factory, replace with the L bracket, the holes should line up with the rivet holes and I bolt it together with 1/4" machine screws, lock washers and Loc-tite on the threads. I also cut one hole off of the side that bolts up to the bike. I haven't had any problems with any of the fenders that I've done this way...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
Advertisers
