Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motor Bicycle Safety
Motor Bicycle Safety Share safety tips for motorized bicycles. Some of these bicycle engines will reach great speeds and need respect.
Do I need to drill the frame?
Discussion at Motorized Bicycle Engine Kit Forum in the Motor Bicycle Safety forum. I saw in passing a mention of how the chain tensioner can come loose and flip into the rear spokes ...
Old 11-03-2008, 11:43 PM
Finfan's Avatar
Default Do I need to drill the frame?
I saw in passing a mention of how the chain tensioner can come loose and flip into the rear spokes with disasterous effect. I also read on the Spooky Tooth site that they recommend holding the tensioner in place with a set screw. Does that mean I should drill a hole through my frame and run a self threading screw in to hold the tensioner in place? I am definitely into pain avoidance so I am wondering what the proper procedure is for dealing with this issue. Currently I am tightening the bolts every night after I ride but I want to do as much as possible to make my cruiser safe. Thanks for any feedback!
-and-
I'm not lost, I'm exploring!
Old 11-04-2008, 07:18 AM
Bikeguy Joe's Avatar
Default Re: Do I need to drill the frame?
chain tensioner modification
Old 11-04-2008, 09:32 AM
OSCAR383's Avatar
put a screw thru the frame and the tensioner. or if you know some one with a welder have them put a couple of tac welds to keep it in place.
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
Old 11-04-2008, 12:28 PM
The rear stays are not large and drilling would weaken them too much I think. There are two things you can do to make this part grab your bike. You can cut some strips of soda can and wrap your stay until it is large enough so the Idler bracket will grab and hold fast. Or..You can simply flip the half moon bracket around and using longer bolts then clamp it down tight. Both methods have worked very well for me. I have not tried the flipping method on an aluminum rear stay yet. But for steel, both methods are good. Enjoy the ride...
visit www.thatsdax.com
Old 11-04-2008, 02:45 PM
HoughMade's Avatar
See below. Steel frame. #8 socket head screw- drilled, tapped, red loctite.
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 11-04-2008, 04:58 PM
...or this- Cupped washers for chain tensioner
Old 11-04-2008, 06:31 PM
Saddletramp1200's Avatar
My 2 cents. Drilling the frame is NOT a good idea. I take some metal and place it on the ground, concrete and an old piece of wood and bend the metal to fit inside the tensioner. I am still with Cruiser on this, If you don't need the thing, don't use it.
Only Bikers know why dogs love to stick their heads out of car windows,
Old 11-06-2008, 02:23 PM
I took two 3/8in x 3in axle keys and welded them to my chain stay it works beautiful and allows you to adjust to the chain stretching.
  #9 (permalink)
Old 11-07-2008, 10:44 AM
MotorbikeMike's Avatar
Dealer
Hi Hse, your bike will perform better if you remove some of the links in your engine chain, slide your tensioner forward and then re-adjust.
The ideal situation on a chain sprocket, is 50% of the teeth engaged with chain. When I look at your pic, you only have about 11 teeth not engaged.
Power is lost by all the extra chain contact, and the fact that you are letting the chain "climb" the rear sprocket.
Try it, and see if you can feel the difference?
BTW on frame drilling, I NEVER have drilled ANY bicycle frame, with the exception of drilling thru the crown on very old american bikes, to install front brakes.
Mike
www.ezmotorbike.com www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
  #10 (permalink)
Old 11-07-2008, 12:23 PM
mechanickid's Avatar
i have 2 cents as well to add.
i took a flat piece of metal about a foot long and attached it to the chain stay and the frame piece above it, it worked pretty well. but i think taking a small flat piece of metal and replacing the clamping piece that is too rounded would work better.
