Reed valve on the cheap
sharkcruiser
71
charleston sc
I recently completed a homemade reed valve setup and tested it for the first time tonight. It is compiled of 100% recycled material I had collected .
The reed itself came out of a discarded homelite Super 2 chainsaw with a Walbro HDA carb. I wanted to try it with the stock carb first and eventually utilize the Walbro.
The block is made out of a bracket from a pipe hanger that I cut three pieces out of. I traced the reed valve onto them and drilled out the pattern and filed the edges until it fit. There is gasket paper between each piece of the block.
This is still in a test phase but so far the setup functions like its supposed to.
The engine is a lot quieter, the throttle is more responsive, and overall acceleration has improved.
I will post more info and a video on it over the next few days. I intend to refine it a great deal, but part of my experiment was to see just how grassroots this mod could be done and still work. So far I think I have about $7.00 and all day Saturday and Sunday tied up in it.
I made the whole thing using a cordless drill, a dremel tool, and a few hand files.
[/IMG]
sharkcruiser
71
charleston sc
I anticipated a little bit of tuning was going to be involved to get this application dialed in just right. Being that I had already done some mods. the engine itself is well past its prime and the reed has definitely brought new life to it. With the little bit of riding I did just the motor "feels" more reliable not to mention how much quieter it is.
As soon as you let the clutch go there used to be a little hesitation as the motor engaged and tried to get with it. That is is all gone. A lot more pull when just starting off.
There is no more chunky sluggishness in the low RPM range just before getting on the pipe. It is all quiet smoothness right into the pipe's power-band.
I'm going to find a road this afternoon to "Stretch it out" to WOT and see what happens.
sharkcruiser
71
charleston sc
Well, it took longer to warm up than I was expecting. Lost the adjusting screw on the carb somewhere. Put in a replacement and it ran pretty well. The throttle cable is binding up somewhere and needs to be worked out. I the pressure in the crankcase is considerably higher. I can see the gasket is getting moist in some spots, which was to be expected. I will be checking the crank bearing seals soon I'm sure. It definitely winds up tight and fast.
At wide open throttle it starts to surge a little bit. I haven't noticed an increase in over all top speed but getting there is a bit quicker.
A few more pics.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
sharkcruiser
71
charleston sc
Update:
I made some adjustments to dial it in and performs really well so far. Initially, the plug was showing a lean condition and I wasn't quite getting to the same top speed. I took the block apart and plugged the hole for the pump on the carb it came with and cleaned and reapplied RTV. I also moved the slide needle clip down a notch to raise the needle. I also added about an inch to the exhaust header. This combination has restored the top end of the motor yet the idle is a little ruff.
the torque is definitely stronger. It has this little hop to it now where the front wheel comes off the ground a few inches when you let the clutch in and throttle up.
It is maxing out the rpms without hitting WOT and I will probably be getting a smaller toothed sprocket to help out.
I still believe there is some uncorked goodness in the engine that can be gained from doing some porting. Before I get into all that I am going to hook up the walbro and try running it to see how it performs before pulling the cylinder off.
So far so good. The only thing I would really like to change about the set up is having a chunk of plastic, like the reed valve is made of, instead of using those metal plates. I have 50cm intake studs now with 1cm anchoring the other 4cm on there. But hey, it least its working.
Goat Herder
Gutter Rider
Apr 28, 2008
6,237
20
38
N.M.
I got a WJ-116 Walbro here. I called numbers on the phone over the internet to get this part number! It officially dials up to 80cc without overkill. So the the carbs jetting screws should be on the map with this one as I can dial it down. Yet another project i got a couple of aluminum blocks already mocked up for it. Your making me wish I had reeds about now!
DanielMaia
309
Portugal
Can you explain, in theory, how this works?
I thought that, less lenght between the in port of motor, and the carb, is the most perfect conditions to improve overall performance, but how you describe, you put 3 pieces of metal..i didn't get how this improve the performance.
Sorry of my noob terms :)
thanks in advance
NunyaBidness
1,062
2
38
memphis tn
In those 3 pieces of metal is the reed valve. What this does is allow the gas/air mixture into the cylinder without letting gas/air mixture back into the intake. This is what improves the performance.
sharkcruiser
71
charleston sc
thanks in advance
The idea is not about changing the distance between the port and carb for performance. I had to use the metal to hold the component going in between the port and carb. It's the main focus of the modification. It's the reed valve which is like a tiny one way trap door. Entrance only, no exit. That way any fuel drawn into the motor stays inside instead of being blown back out the intake on the piston down stroke. I know where you're coming from though, it's information overload. Keep thinking hard and you'll get it.
DanielMaia
309
Portugal
Excelente explanation Nunya and shark, now i got it :)
That "reed valve" is easy to get? Any change is comsumptions? (economy) better or worse?
Relation performance/economy, increased?
thanks guys :)
sharkcruiser
71
charleston sc
Easy to get yes, in my opinion. The consumption depends on how you ride, so far, it hasn't been worse for me.
Part of the theory behind this device is that it lengthens the overall lifespan of the engine. It helps in a lot of ways but our engines did not come to us set up for these. So there will be formulas for timing, consumption, etc. that are altered and will have to be corrected. That is basically what we mean by the phrase in English, "dialing it in".
DanielMaia
309
Portugal
Nice to read that :)
I was thinking..it needs so big pieces of metal, to put a reed valve? Cannot put only a few little pieces between port and carb?
How big is the reed valve?
Thanks ;)
sharkcruiser
71
charleston sc
Thanks ;)
It is 15mm diameter. It is the black piece in one of the pictures earlier in the thread. This is just an experiment with different variables. I could have used another material, and probably will, but the metal is what I had on hand.
DanielMaia
309
Portugal
I loved that bike, sounds really good!
I have my m.bike, that the idle is really unstable. If the motor is cold, i push the cluth, the motor stop, when the motor is hot, rpm just raise too much and i have to press the kill switch because is really noisy.
Sometimes i reajust the idle screw but are these 2 cons. In cold, the motor stops, when it's hot, the rpm raise too much.
reg454
269
michigan
From the simple setup you could get parts cut out and sell the custom reed kit for cheap. It all depends on how many you want cut out on the first run. I fyou were to make the cad program youself you can save alot of money that way they just have to input it and cut you can do everything else like applying the rtv to the 1/4" plates and making the little valve.
also have you tried getting a shorter intake because if you were to subtract the amount you put on you would get your performance back.
DanielMaia
309
Portugal
I didn't get some of what you said..
I can make a reed valve and sell for cheap? where i can get one? it's a specific valve that only mechanics have? the plates are only to hold the reed, right?
thanks reg
This is the valve, right? you made it?
