Ok fellas here's the deal.
I bought my engine just before this winter and its run great every time ive had a chance to ride it. After getting home for summer ive been riding it in the higher temperatures and ive noticed a huge decrease in performance.
Basically, my engine runs great for the first 3/4 of a mile or so under wide open throttle. After that, if i dont cut back on the throttle it seeems to lose most of its torque. With varying throttle positions i can still open it up every once in a while to get a good burst of speed, but constant cruising above 30 is not an option right now. Also, when going up long gradual hills ive noticed that my engine becomes rediculously sluggish, even after getting back to flat ground.
I've decided that the problem is that the crank case of my motor is getting too hot. This makes the intake air too hot preventing my engine from breathing enough O2.
If someone could verify this that would be great.
If this is correct, my proposed solution is to completely seal off the cooling fins on the bottom half of the jug with a tire inner tube and to connect them in such a way that i can pump water (coolant) through them and then through a small radiator to allow my crank case to stay cool and my intake charges dense.
If i had a metal lathe I really wanted to make a water cooled head too...but i dont.
I will probably try it either way but let me know your thoughts.
