This is my current build. A bike for fun. Started with an abused Diamondback frame from the 90s Im guessing. Came off ebay disassembled in a box for $30. Have been piecing it back together with decent but lower end stuff as its really a street rider. Trying yo keep it as light as possible. I was told that the MP2 was a 1200w unit. Havent run the specs thru the simulator yet but have it geared high for assistance above 30mph. Has a 52t single front ring with 7speeds from 14-34t rear. Cant believe the chain clears the smallest cog but it does! Will be running my latest battery which has been raised in voltage by the addition of one more 7.4v cell making it a 15s/55.5v nominal battery. Will come off the charger at 60+v. The GM controller will handle the voltage. The battery will fit nicely in the triangle using the threaded inserts for the water bottle, and the controller above it on the lower V of the shock mount where strangely there are two more threaded inserts in perfect position. Not real obvious in the pic is the wiring has been cut. Will run it directly to the controller plug ins instead of trying to hide it all some where. Will also eliminate the second set of plugs supplied stock. Has been an easy build so far. Some builds just seem mean spirited this one is not.
