How tight should I tighten the sprocket bolts?
SeattleMike
67
Seattle, WA
Ilikeabikea
2,322
68
Ptown, Texas
I used 1/4" drive ratchet and tightened about as tight as I could with one hand. I didn't get brutal or anything just good normal tight. I started out with them just snug and went round and round tightening them trying to keep sprocket straight. Hope this helps.......................
SeattleMike
67
Seattle, WA
I should have read the instructions that came with my kit instead of looking at those picture instructions from zippycycles.com ! The photo of the sprocket shows both rubber washers on the inside of the spokes, rather than one on the inside and one on the outside like my instructions say. I have a feeling my instructions are right, what did you guys do?
bgoates
85
The instructions I saw recommended a rubber washer on inside and outside only for bikes with coaster breaks. I'm not sure why that would make a difference.
Norman
LORD VADER Moderator
Jan 16, 2008
2,606
7
38
71
pampa texas
Follow our instructions and you will be successful if you don't understand anything don't be afraid to ask. I use the fiber gasket on both sides to get a good grip on the spokes, keeps the sprocket off the spokes, provides space to aline the front and rear sprockets.
Norman
deacon
minor bike philosopher
Jan 15, 2008
8,114
9
north carolina
I agree its the only way that makes sense. Metal and metal will never grip like that wrap around fiber.
I tightened mine till I felt like the nut stopped moving, not till the puller handle bent. But you should check it now and then, as it will probably get loose after a while. Everything gets loose after a while
Dave31
11,199
47
38
Aztlán, Arizona
I used a inch pound torque wrench to be sure I got them all the same tightness, and loctite. For the life of me I cant remember what I tighten them too :confused: Do not use a ft. pound torque wrench or you will tighten them too tight.
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
I don't know what I mean...I've ever only used a foot pound wrench.
I have developed a "feel" for bolts and only use a torque wrench when doing something like the heads on autos.
If you are tightening the sprocket bolts, make them "reasonably tight" don't go apesh*t, but make sure they aren't going to come loose.
HoughMade
623
Valparaiso, IN
I tightened mine to about 12 ft/lbs (not inch pounds)- but that is working up slowly and with the 9 original bolts replaced with quality bolts. I take a Sharpie and number the bolt holes 1 through 9. then I tighten number 1 down a bit, then 6, then 2, then 7, then 3, then 8, then 4, then 9, then 5, then 1.... Sharpie comes off with laquer thinner. When I get close, say 9 or 10 ft/lbs, I put a straight edge across the sprocket at several places to make sure the sprocket is equidistant from the rim. I then adjust if necessary by tightening where necessary to equal it out.
Oh yeah, one rubber disk outside, one on inside, but my kit came with 2 metal split rings, one made of three pieces with 3 holes in each and one of two pieces, one 4 holes and one 5. I put both of those on the inside, overlaping the joints.
When I took the sprocket off of the old wheel to put it on the new one, the pattern impressed on the rubber showed that the bolts were neatly between the spokes and not resting against them- that is what you want. If you do not tighten them enough to have that happen and have the sprocket stay put, trouble will follow, especially if you are using standard 14 ga spokes.... imho, at least
nogoodnic
509
Shelby MI
forum1.freakbikenation.com
I use almost exactly the same method as HoughMade, although I have never used a torque wrench. I tighten mine down pretty tight with usually 3-4 threads sticking out past the nut. The biggest thing is to keep metal off ot the spokes, I learned this the hard way with seven spokes worn through...Kelly
sisdavid
257
Daytona Beach
My technique on torquing bolts on the rear sprocket is to count threads. How many threads are sticking out of the bolt after tightening. Tighten in a criss cross, like a car tire. tighten untill I have two threads showing out the top. Then criss cross tighten till three, and finally untill I have 5 showing out the top and make sure that all of my lock washers have colapsed, finger nail polish on the top of new bolts and threads seems like a good idea to me that red lock tight is kind of powerfull and the blue is kind of wimpy. I like finger nail polish. Hope that does not make me gay right?
