morini S 5 K engine
1heybuddy
2
Ca
I have a old morini S 5 K engine that was sized up i replaced the piston and rings the cylinder was fine. I only get about 15 pounds of compression when I tested it. The engine won"t start and i'm not sure how much compression it should have. Everything else has been fixed i rebuilt the carb and the spark plug has great spark but won"t start! Help !!!
dmb
1,354
3
36
lakewood ca
the reason i asked was that i have some parts you might need and these s5 parts are gettin hard to find. good luck
1heybuddy
2
Ca
I'm in Simi Valley, Ca.I think i need to put in an over sized piston and have the cylinder bored out to fit it.This will hopefully increase the compression and get it to run.
dmb
1,354
3
36
lakewood ca
that can cost some money besides the piston after you bore it you need to plate the barrow. i'm dont know what a s 5 ''k'' is but i do have some top ends that will fit. they are 3.5 hp that run real smooth. pm me with your ph# and we can talk. im not in this hobby for money so dont worry about that. dennis
