The mtb front wheel drive has morphed into this bike..
It now has a 31cc ryobi WW engine and a suicide clutch. I still have to get used to the clutch and the fact there is no front brake on this one. the coaster brake will stop it pretty quick and if i get off the gas it will roll to a stop as well.
I rode it on the one mile test track and it did pretty good. I had to stop short twice to adjust the controls. It did just fine once I got the controls right. The cable for the throttle has been used and reused so many tile I had to put a sping on it to make it return. It's the first bike I ever had to do that to the front throttle. All the rear engine needed the helper spring.
It has a rhythmic thump when it runs along. I can't see any reason for it but it does have a semi knobby tire on the front. I thinking about changing it for a smooth tire. I might do that tomorrow just to see if it helps. The wheel I'm going to use is 26". It might also change the angle of the engine so that I might use a brake lever for the clutch again.
I swear I love the WW engine bikes even though there are some things better about the chain saw bikes.
All my bikes except the china bike have 20" coaster wheels. It makes it much easier for me to mount and even to pedal since they also have the short crank set from the 20" bike as well.
