WEll I have built Gas kit bikes, I have built weed whacker bikes, I have built chainsaw bikes, I have built e bikes out the butt so I feel like I am qualified to say this. Pound for pound I love the ebike better BUT and you will note it is a big butt. There is the battery and everything associated with it problem/.
The good about the ebike for me. You turn the throttle and it goes, and with much less vibrations to beat itself apart. No clutch to worry about. If you have it wired right it is going to go. They have good torque when you pull away and good speed when the torque is no longer needed, if you have the right sized motor power setup. It's like gasoline bike engines, the bigger the motor the better the performance.. The better the performance the more energy it sucks up. In the case of the ebike, the amount of energy available is finite. You can't pull into the local power company and filler up, then dive away five minutes later. To sum it up I hate to do it but I'm going to bail on the ebikes.
Alas poor Tesler I knew him well, but he did not smile kindly on me.
So why after all this time you might ask. To be honest I have a terrific drive system. The Rhino friction drive is probably the best drive I have ever built. The problem is the batteries. Put them on the bike and it is a death trap balance and weight wise. The trailers I built were okay but they always left something to be desired. I love the faux trike, but even that doesn't have a sense of strength to me. I have to wind down the other pieces of junk I have been working on. Then I should sell some of these E scooter motors I have laying around. I have some controllers as well that I will never use.
I expect to be building something else real soon. Maybe I can find a small gasoline engine to power the Rhino drive system. Anyway there will be no new experiments from me for a while until I decide where to go next.
