Hello, I wanted to share my knowledge here in the engine mount section. I've been through it all, stripped studs, snapped brackets, and oh, the ever torturous engine tilt. If you have this problem, when the engine is tilting to the left because the mounts keep slipping, then I have your solution!!! This will not allow your engine to tilt anymore, and also doubles as a vibration reducer! If you have Nylock nuts on your engine mounts, then once you use this stuff, you'll have no more worries. So here it is. It's non-slip mat, I got it at a dollar store for a buck. It comes in a long roll, so for a buck you can mount thirty or more engines before you need to buy another roll! Here is a couple pictures, and a link to a video where you can see it also. I hope this helps you all, good luck, and ride safe!
Video: VID2000166.flv video by ADDICTED-BICYCLE-CUSTOMS - Photobucket
