PDA
View Full Version : Mounting Techniques for Bicycle Motors
Pages : [1] 2 3
  1. preserving your motorized bicycle frame
  2. Lonesome Rack'ee
  3. Moutain bike - clutch/brake lever??
  4. Frame question sorta.
  5. Motorized Bicycle OVERSIZED TUBING solved
  6. 1/2 links for bicycle motor chain
  7. My Chain came apart!!
  8. Incremental Chain Tensioning, Chain Management
  9. Eliminating the driven sprocket
  10. Just "screwed it on"!
  11. How tight should I tighten the sprocket bolts?
  12. attaching sprocket.
  13. Choke lever acces from handle bar
  14. Modify the mounts or the frame
  15. Spring Return Chain Tensioner
  16. How to build a friction drive
  17. A diffrent drummer
  18. Mounting the clutch handle
  19. Transplanting motor to new bike, derailer issues
  20. Ideal bikes to mount my engine???
  21. Carborator adjustments
  22. Pedal not clearing the Exaust
  23. Enlarge Sprocket Center?
  24. Stopped Gas Tank Leak
  25. Moon Dog Question
  26. Foot Pegs
  27. exhaust pipe clearance
  28. JB Weld on mounts
  29. dealing with brake/shifter lines
  30. Spark Plug Clerence
  31. solid motor mount and exhaust mod
  32. rear engine mount bracket
  33. Straight chain
  34. Flat rear tire
  35. Motor mounts
  36. mounting a motor??
  37. Brake handle location
  38. Just how wide is a Wide Pedal Crank?
  39. Chain tensioners
  40. to big ?
  41. chain is eating my tire.
  42. clutch handle install
  43. Help To Mount Motor On 20" Stingray
  44. Oversize frame mounting bracket
  45. GEBE mod
  46. China Girl Motorized Bicycle Kit with different carb angle?
  47. Help with seat and down tube dimensions
  48. Changing crankset to 3-piece
  49. Where can I buy one?
  50. Engine Vibration
  51. 49cc on a 16" stingray?
  52. Raise the motor or wider crank
  53. vibration with drill vs. no drill front mount; 70cc
  54. Opinions? 18" Mountain Bike
  55. good vibrations
  56. Balancing China Engines
  57. Mounting Woes- Screws keep snapping
  58. Schwinn "Point Beach" Cruiser
  59. Power transmission ??s will this work?
  60. four cycle motor in frame mount?
  61. Sick Bike Parts Shifter Kits
  62. 27 inch wheels
  63. Will Staton chain drive fit this bike ?????
  64. bike and motormount pics
  65. New way to mount HT bicycle engines!!
  66. SBP now offers crank conversion sets
  67. BGF Motor & 1G long gas tank
  68. My Schwinn cruiser mount.
  69. is there any good mods to the eng. mounts?
  70. Frount mount
  71. Motor mount
  72. Zooma motor
  73. Where to buy the required hardware?
  74. Rubber mount
  75. how do i mount an engine on a stretch cruiser?
  76. mounting chain saw engines
  77. rear sprocket mount
  78. Lead mount.
  79. Bendix 76 Coaster brake.
  80. wheel sprocket?
  81. I need a pusher trailer part source/vendor
  82. First HT bicycle engine kit attempt
  83. Engine Lacking performance after being in cold
  84. engine mount ?
  85. Question? Mounting Sprocket to a coasterbrake hub
  86. First Build Aluminum Frame, Mistake??
  87. Mounting a 2-Stroke!?
  88. Mounting Help!
  89. Mounting Studs Breaking Off
  90. rear mount or inframe...parts same?
  91. Shorten rear mount ??
  92. Mounting Suggestions
  93. my engine leans!?
  94. A better muffler clamp.
  95. My First Build
  96. My buddies version of over sized tubing solved
  97. sprocket problem...
  98. motorizing a tandem
  99. 2 stroke on 24" moutain bike
  100. 3 inch rear tire clearance
  101. Giant Simple good start for Chinese kit
  102. Better motor mounts
  103. Mounting on Schwinn Cruiser Supreme
  104. Various Front Mount Options For Each Type of Bike
  105. Trialer Question
  106. NEED HELP- mounting a 2 stroke engine on Jeep Mountain Bike
  107. what kind of lock-tight should i use
  108. Easy Fix? Please help!
  109. My next problem and I need some advice
  110. How much metal can "safely" be removed from the front mount?
  111. Power Bar
  112. muffler in the way
  113. Gas Tank Relocation...
  114. Worksman LGB motor mount
  115. adjustable chain tensioner idea
  116. A Simple Cruiser Front Motor Mount
  117. Help with ghetto mounted gas tank
  118. Help with a chain problem
  119. How I mounted my aftermarket kill switch
  120. Need some advice regarding front motor mount
  121. Plate mount
  122. Pedal hits muffler
  123. stupid jag
  124. What to torque motor mounts at?
  125. Mounting Gas Tank
  126. How to mount exhaust muffler for no peddle hit
  127. Notice: Stretch Cruiser Mounts
  128. Stripped 6mm Threads
  129. felt leadsled
  130. custom mounts with shift kit...?
  131. worksman mounting
  132. What Type Of Loctite
  133. Best engine mounts for oversized tubes
  134. Chain Rubs Frame
  135. Totally ruined right rear mounting hole... now what?
  136. Inner Tube On The Frame
  137. Huffy Cranbrook Mounting Problem
  138. Full suspension??????
  139. Vibration tip
  140. Schwinn Landmark Mounting
  141. A Store To Buy Chain At
  142. OCC Stingray first time
  143. JNM Super Mount
  144. help! i need some brainstorming for this one.
  145. large lower frame tube
  146. wcc jesse james chopper mounting help.
  147. can someone have a look at this?
  148. Engine on 18" frame?
  149. where did the occ motor mount blueprints go?
  150. Threadless beach cruiser?>
  151. Large Universal Front Mount Cracked
  152. Orientation Question
  153. To big .. store
  154. What type of studs/bolts/allens would you recommend?
  155. Need length of hex bolts to replace mounting studs
  156. Need Enging Mount FELT Bike
  157. coast brake sproket mounting
  158. Just got a Worksman!
  159. mounting brackets
  160. Rear Disk as Sprocket Mount
  161. trek classic cruiser
  162. Are You Sick Of You Bolts Snapping!!!!
  163. Atom Brake Sprocket Mounting
  164. Where can I find these parts ( sorry, spent 20min using search)
  165. Weed Wacker Mounting Idea
  166. Motorcycle gas tank. Mounting?
  167. Timberline fs gt?
  168. motor mount help on a pacific evolution
  169. The Most Stable Medium!
  170. $2 front mount fix for cruiser frames
  171. My heavy duty 4 stroke engine mount.
  172. my proposed front mount
  173. Four stroke custom stretch build
  174. Spacer for rear mount question
  175. Womens Bike Motorized Bicycle Kit
  176. 1957 western flyer motorized bike project
  177. occ stingray
  178. my front motor mount
  179. EZM Dresser Build
  180. Tubing size on Schwinn Landmark
  181. 68 spokes
  182. schwinn custom motor mounts
  183. Clamshell adapters
  184. Installation Instructions?
  185. Vendor Installation Manuals
  186. Motor Mounting on Trek 3700
  187. Solid Forks 2 Sus. Forks
  188. Comments requested for Newbies mount plan
  189. Dellorto Carb & Throttle Clearance
  190. brake noodles for clutch and throttle clearance problems.
  191. oval bottom tube on a GT mountain bike?
  192. re-purpose old leather belts
  193. Tensioner or No Tensioner
  194. Electra Ghostrider
  195. easy rear engine mount
  196. Rack mount advise for a womens bike.
  197. delmar hub measurements?
  198. Muffler Clamps
  199. solid or rubber mount engine?
  200. offset motor mount?
  201. How about a frame that's not exactly round...?
  202. Wide Engine Mount Spacer
  203. HT Bicycle Engine Kit with Firmstrong Bruiser Prestige
  204. How much space
  205. How wouled I mount a engine to this?
  206. Mounting on a Huffy Cranbrook
  207. Manic Mechanic Engine Mount
  208. Can somebody recommend a engine mount kit for the Nirve Classic?
  209. Grubee to Monark
  210. frame too small for 4 stroke. smaller crank sprocket?
  211. spookytooth/schwinn cruiser engine mounting
  212. I'm sure I'll feel pretty stupid after reading your answers...
  213. Standard 66cc Engine Stud Width?
  214. new killswitch location
  215. Is roller centering critical?
  216. Advice needed on engine clearance for 1st timer
  217. Could you do a rack mount on this bike?
  218. Updated "Stretch" cruiser mounts
  219. Apollo bike, will it work?
  220. Help w/ Custom Chain Tensioner
  221. how easy is it to put a kit on a bike?
  222. cheap spring loaded tensioner $5
  223. front motor mount broke..
  224. Petcock hitting frame,what now?
  225. Block mounts+drill
  226. MICARGI DOWN TUBE SIZE??? So can get Ubolts.
  227. kustom pivoting rear motor mount
  228. Chain Alignment
  229. Motor mount alignment?
  230. wiring up a light
  231. Dual Pull Break leaver with combined shifter / Break unit?
  232. Mounting a fuel tank on bikes with bare cable on the top tube
  233. Had my Spooky Tooth kit a year! Please help!
  234. Motor mounts and the jaguar
  235. Good Chain Tensioner.. Self Made..
  236. just made this motor mount.. for my cruiser
  237. Rear engine mount help
  238. Rubber mounts
  239. stinger front mount stud spacing
  240. Rear mount spacer, what does it do?
  241. Potential issues mounting engine?
  242. Exhaust pipe clearance
  243. pedal wont clear muffler or motor
  244. I think I'm going to need a new 4 stroke mounting plate.
  245. Best mounting on aluminum frame?
  246. Alignment?
  247. Nord-Lock locking nuts - anti-vibe fix
  248. Engine mount is driving me nuts.
  249. general mounting questions
  250. 26" Mens' NEXT PowerX Dual-Suspension Mountain Bike
